Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1967 - 1972 Chevy/GMC Suburbans & Panels Message Board > 1967 - 1972 Chevy/GMC Suburbans and PanelsProjects and Builds
Old 11-05-2025, 04:47 PM   #326
HO455
HO455's Avatar
Re: NJ Suburban
Congratulations!
RIP Bob Parks.
Old 11-05-2025, 09:46 PM   #327
67swb72klb
67swb72klb's Avatar
Re: NJ Suburban
Originally Posted by pwdcougar View Post
I bought the truck from a guy in West Milford NJ 14 or so years ago. It's the same truck I owned in Rockaway NJ from 1983 to 1997! Not sure it's the same truck you are thinking about.
First picture is when I bought it in 83, second is in 97 when I sold it and the last when I bought it back.
I was referring to the 68 you are using for the body...
Congrats on the retirement too...
California 65 GTO---Texas 64 burb 283 ---Oklahoma 67 CST SWB BBW wood bed 327 2004r---New Mexico 72 k10 350 350 auto---Georga 72 short step project
67swb72klb is offline   Reply With Quote
Old 11-05-2025, 11:41 PM   #328
LockDoc
The Older Generation
LockDoc's Avatar
Re: NJ Suburban
Leon
Old 12-03-2025, 10:24 PM   #329
pwdcougar
pwdcougar's Avatar
Re: NJ Suburban
I spent the day lining up the panels and gaps. Looks like some work is needed on the body lines. The top body line just below the window is set. The concave line just above the door handle is too high and the lower body line is too high on the door.
"You know that little thing in your head that keeps you from saying things you shouldn't? Yeah well, I don't have one of those"
1969 Mercury Cougar Standard 4 speed
1969 Mercury Cougar XR7 convertible
1970 4WD Chevrolet Suburban
1997 4WD Chevrolet Silverado Extended Cab Short Bed (purchased new January 1997)
pwdcougar is offline   Reply With Quote
Old 12-03-2025, 10:26 PM   #330
pwdcougar
pwdcougar's Avatar
Re: NJ Suburban
The 68 body came from way the heck up in Michigan. Was that you?
Old 12-05-2025, 09:25 PM   #331
HO455
HO455's Avatar
Re: NJ Suburban
One thing I discovered too late on mine was the window frame wasn't attached to the door properly at the factory. I thought I had things aligned pretty good but after painting I discovered the window frame hitting the A-pillar when opening the door. Basically I can set a nice gap around the window frame or I can have the body lines match up but not both.
Someday down the road if I have to repaint the Burban I will cut the window frame loose and weld it in the correct position.
Good luck with the alignment it can be frustrating.
RIP Bob Parks.
Old 12-06-2025, 04:35 AM   #332
67swb72klb
67swb72klb's Avatar
Re: NJ Suburban
Actually it was a friend I went to school with I went with him when he bought it and got it running after we brought it home..
