1966 Suburban Saginaw shifter keeps popping out
I’m working on my friends 1966 suburban and the shifter keeps coming up and out of the transmission, anybody know of a retaining clip kit of some sort?there is a spring and a cap that is loose on top of it. My Google skills have gone down the drain
Re: 1966 Suburban Saginaw shifter keeps popping out
Pretty sure that collar you're holding, needs to be pushed down and turned. One direction or the other to " lock " it down, iirc
![]() Join Date: Feb 2011
From another thread here;
-push down on the collar and rotate it counter clockwise, collar will pop up then pull stick up and out. Attached Images
MusicMan70 1961 GMC Suburban |
There should be two pins inside the shifter tower that the cap hooks onto. Are yours missing?
65 short stepside K10 292-SM420-T221 8 lug closed D44 front NoSpin HO72 4.10 rear |
Ok thanks for the replies guys. Upon further inspection it looks like the two hooks on the cap are basically non existent. Idk if I can buy another one but maybe I’ll just drill this cap out a little bit to make some new hooks.
Looks like somebody did a little welding on the cap before too.
Looks like Novak can sell you exactly what you need, give them a call
| Bookmarks |
