Old 11-24-2025, 11:18 PM   #1
0ldSoul
0ldSoul's Avatar
Another '63 Restomod Build
Well we sold our previous truck before having to move again (military), and I missed it since we saw it drive away. With moving and buying a home, I don't regret it - it's got us to where we are today.
Anyhow, fast forward nearly 3 years and we found another kneeknocker. This 63 was in Idaho and, according to the seller, appears to have been an Idaho farm truck its entire life.
The plan is to have it on air. We're going to cup the control arms and do a mild c-notch, but the Chopping Block rear half and cross member look pretty sweet!
For get up and go, we're thinking an ls with either a 4l60.
Power steering and disc brakes all around should make it comfortable and safe to drive.
The 8 hour drive from Vegas to Idaho Falls was... long driving through Nevada is boring - not much to see!
[B]Here's a picture of the C10 on the trailer
The view from our hotel room
Grabbing coffee and donuts for the roadtrip
and finally, home
Current: Another 1963 C10 - Build in progress
Sold The '63 Restomod Build - 283/4 speed, 4.5/7 static drop, disc brakes, power steering
0ldSoul is offline   Reply With Quote
Old 11-24-2025, 11:59 PM   #2
0ldSoul
0ldSoul's Avatar
Re: Another '63 Restomod Build
Well, the interior is done
Got right into it and began removing the front clip
Old 11-25-2025, 12:04 AM   #3
DPowers
One foot in front of the other
DPowers's Avatar
Good looking solid truck.
DPowers is offline   Reply With Quote
Old 11-25-2025, 12:15 AM   #4
0ldSoul
0ldSoul's Avatar
Nice thing about the long bed is we have a place to put all the parts haha
I can't describe the amount of caked on dirt
and what on earth is that welded to the front crossmember!?
Front clip off, and lots to do!
Old 11-25-2025, 12:18 AM   #5
0ldSoul
0ldSoul's Avatar
Steering box and linkage removed
Always a fun time with ball joints
time to clean up again
....and get everything dirty again
Old 11-25-2025, 12:29 AM   #6
0ldSoul
0ldSoul's Avatar
Sorry for the picture dump, but this is just to document the progress put in, day after day..
What's that saying? Good work isn't cheap and cheap work isn't good?
Our daughter helping out
Old 11-25-2025, 09:44 AM   #7
joesscamaro
Making good progress! Looking forward to more updates.
joesscamaro is offline   Reply With Quote
Old 11-25-2025, 11:30 AM   #8
SCOTI
SCOTI's Avatar
I'm in to watch. Looks like a decent starting point.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 11-26-2025, 11:09 AM   #9
rbruno68
Nice to see another 63. What is the two master cylinders? At least it looks like two bolted to the firewall.
rbruno68 is offline   Reply With Quote
Old 11-26-2025, 11:39 AM   #10
SkinnyG
SkinnyG's Avatar
Excellent time to pancake the crossmember.
Or go Porterbuilt, or NoLimit, or something....
(big grin)
1961 Apache: "Grabber Orange" Shortboxed, pancake, step-notch, air-ride, turbo, LS
1977 Silverado: Shortboxed & dropped, potato-potato
V8 Pontiac Firefly (Chevy Sprint): The ultimate engine swap: 5.7L in a 1.0L bag
Lotus Super 7 Replica: Scratch-built street-legal rollerskate
SkinnyG is offline   Reply With Quote
Old 11-28-2025, 10:20 PM   #11
0ldSoul
0ldSoul's Avatar
Thanks Joe
It's not terrible, definitely one worth saving!
Yeah.. we wondered the same thing lol
Thanks, we're going to rock the patina look for a bit.
(big grin)
Going to cup the front control arms for now, but we are looking into eventually doing the Choppin Block dropmember and rear backhalf
Old 11-28-2025, 10:42 PM   #12
0ldSoul
0ldSoul's Avatar
I've been off this week, so I've been able to work on the truck more than ususal.
We're going to try doing the vinegar bath on a few parts.. we've done it on a previous build but I can't recall if it made a noticeable difference or not, so we'll see.
Moving onto the front crossmember
Primer
Paint
Old 11-28-2025, 10:48 PM   #13
0ldSoul
0ldSoul's Avatar
Firewall done, for now. We'll eventually cover that hole from the '2nd' master cylinder
Can't wait to see gold grade 8 bolts against that shiny black!
Old 11-30-2025, 11:51 PM   #14
PowerdbyChevy79
PowerdbyChevy79's Avatar
Subscribed...
1966 C10 "Mary"
1967 C10 Custom "Ole Blue"
1972 C10 Cheyenne "Betty" https://67-72chevytrucks.com/vboard/...d.php?t=847364
1979 C10 Silverado "The BIG TEN"
C10 Club Texas -HMIC
PowerdbyChevy79 is offline   Reply With Quote
Old 12-06-2025, 10:25 PM   #15
0ldSoul
0ldSoul's Avatar
Crossmember is back on and got some items ordered over the last couple of days.
Old 12-08-2025, 07:13 AM   #16
joesscamaro
Looking clean!
Old 12-08-2025, 09:59 AM   #17
rbruno68
Looks great. The frame and firewall really cleaned up nice.
Old 12-08-2025, 11:57 PM   #18
0ldSoul
0ldSoul's Avatar
Looking clean!
Thanks Joe! Any update on your 65?
Yes they did, we were amazed at how much better it looked. Although it's time consuming and one can easily lose time sanding away, it's part of the fun and satisfying when you see it all come together with some fresh paint at the end.
We do plan on moving onto the middle of the frame next. For now, the plan is to figure out how to lift the cab - at least some - to thoroughly get the frame and cab mounts as well as replace those body bushings while we're at it. We're looking at the OE rubber since I've read the poly bushings can be stiff.
Old 12-09-2025, 12:05 AM   #19
0ldSoul
0ldSoul's Avatar
So, I read this was a popular upgrade: 1973-1987 LCA u-bolts
Step drill bit and 9/16 bit took care enlarging the crossmember holes
Old 12-09-2025, 01:16 AM   #20
SCOTI
SCOTI's Avatar
Yes..... They are a good idea. Moving the lower arns slightly forward is as well.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 12-09-2025, 10:13 AM   #21
rbruno68
How did your bolts/nuts fit up against the top side of the crossmember? I used a die grinder and tried to move the holes away from the crossmember and they were still very close and hard to get a socket on.
Old 12-09-2025, 10:39 AM   #22
SCOTI
SCOTI's Avatar
Same issue. I recall final tightening was via open-end wrench.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 12-09-2025, 08:05 PM   #23
0ldSoul
0ldSoul's Avatar
Funny you say that, when I mocked it up for that picture, I was wondering if that would be a problem.
I'll try the slow going open-end wrench, but if need be, thanks for the die grinder idea.
Old 12-10-2025, 10:07 AM   #24
SCOTI
SCOTI's Avatar
I took a 'hammer on ball-peen hammer' approach as well as needed. A couple of good clean whacks helped.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 12-13-2025, 01:01 AM   #25
0ldSoul
0ldSoul's Avatar
Noted!
