Old 12-02-2025, 11:41 PM   #1
chris989
Cruise control female end of the plug
Hello all,
1989v2500,
My truck came with cruise control, I removed it. Thought i kept everything and do not remember removing anything from under the dash.
That said, anyone have a source for the female socket (truck side) for the 4 wire flat blade male coming from the stalk?
I could cut the plug off but the wires ar super thin. I want to use the set/push button and cruise on/off for other features, Like running a relay for LEDs and convertor lock up.
Does the truck side of this blade have larger wires that are not so delicate to work with? If not i will cannibalize this thing and move on. If i can find the plug, it will make blinker stalk replacement easier down the road as a plug and play.
chris989 is offline   Reply With Quote
Old 12-05-2025, 07:41 PM   #2
chris989
Re: Cruise control female end of the plug
Hello again,
I see a few people looked at the post, i do not think it can be bought aftermarket and my junkyard has no squares.
Does anyone know where it plugged in under the dash? have a pic?
Thanks in advance
Old 12-08-2025, 09:50 PM   #3
v30crewcab
v30crewcab's Avatar
you can get one out of a jeep xj. they use the same cruise plug and should be easy to find.
88 military v30 crewcab shortbed 5.9 cummins, nv4500, 205
86 k30, 89 diesel burb, 76 gmc pathfinder
71 longbed 5.3 4l80
http://67-72chevytrucks.com/vboard/s...d.php?t=522535
v30crewcab is offline   Reply With Quote
Old 12-09-2025, 12:43 PM   #4
truckin 79
It should be at the end of the steering column right at the bottom, It is usually a white plug
79 Chevy 2wd BIG10 350 TH400
truckin 79 is offline   Reply With Quote
Old 12-09-2025, 01:29 PM   #5
chris989
Thanks,
I will look in the Jeep, the one under my dash is MIA.
