Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > Heavy Haulers
Old 12-28-2025, 03:59 PM   #8
Bigdually
Re: 350 2bbl, worth 4bbl swap?
Originally Posted by LynnB View Post
I doubt you will feel any difference other than in your wallet. I swapped the engine and transmission from a 1972 C50 into my 49 Studebaker 2R16A. The two barrel carb was missing. I had two choices from parts I had sitting around; either use an even SMALLER two barrel intake and carb from a 1968 El Camino that came with a 307, or use a 68 intake and Qjet from a 1968 Chevy 350. I opted for the two barrel and have never regretted that decision. I am a big fan of Qjets (set up correctly) in cars. But really no need in a big truck. I do not drive on the highway often; only to get sod, gravel and dirt. But when I do, I am doing 4200 RPM at 65 mph because of the 6.66 rear axle. Those big secondaries on the Qjet would be open ALL THE TIME.
I ran a Q-jet in that 68 El Camino and it ran flawlessly. Had a 3.31 rear axle and a 4L60E auto overdrive trans. Got great mileage when I wasn't towing. I have the exact same manifold and Qjet in my 57 Chevy and it runs great. But I am sticking with the two barrel in my big truck.
Thanks for the info!
I have had the same line of thought on the swap myself, that with 8.50 low/6.50 high gearing I'll be running with the secondaries open a LOT of the time.
I think that unless someone can tell me otherwise that it's a worthwhile swap, I'll leave the 2bbl alone and just make sure the truck is tuned up as good as possible and see how things go. I do think I'll open the exhaust up with true duals just to help it breathe a little, that was an option from factory. Currently it's got a y pipe and stock single exhsust.
2.5 Ton Pickup Build:
1989 GMC 6000 Pickup/Toy Conversion
Bigdually is offline   Reply With Quote
