Old 12-26-2025, 10:29 AM   #26
b454rat
Re: Leaf spring question
I have a set of ORD springs, I didn't order them but PO spec'd for his truck. It's possible ORD sent wrong springs. Is there a part number or some reference number on them? Rear springs will have the hoover, in less someone took it off. Also, I've talked to ORD numerous times about springs, and don't think it really matters what way the shackle goes. If it did, then they (or would be common knowledge that can't do a shackle flip with stock springs. What ORD states is when doing a flip, it will move the axle forward. Then it will be exaggerated with blocks or lift springs. When they spec a spring, they will ask if a flip is being used, and will move the center pin to center the axle in the wheelwell. In this case, it's pretty clear it's the wrong spring. Maybe if we could get a pic of the springs at the axle??
2000 Chevy Tahoe Limited 3/5" drop
2000 GMC CCSB 454/4L80 6” lift SAS
1999 Chevy CCSB 454/NV4500 4” SAS
1999 GMC Yukon stock SAS 6"
Old 12-26-2025, 01:03 PM   #27
Orange Crate
Orange Crate's Avatar
It does matter which way the shackle goes. As others have highlighted, the way the springs are set up now they will bind and not allow articulation.
72 K20 Custom Camper, D60, 14BFF, full roller 406 TPI w custom built ECU and yes..it has tow hooks, a 5 speed AND a front hitch!
Orange Crate is offline   Reply With Quote
Old 12-27-2025, 11:58 AM   #28
b454rat
double post
Old 12-27-2025, 12:02 PM   #29
b454rat
Obviously it's not gonna work the way it is now. Were here trying to help OP with the issue. He needs to get ahold of ORD, somone messed up either way.
Old 12-28-2025, 09:54 PM   #30
v30crewcab
v30crewcab's Avatar
those springs are too short for either shackle setup. I know what a tension shackle setup looks like, as well as a shackle flip. I have about 6 different 4x4 squares in the yard currently, as well as a 71.
88 military v30 crewcab shortbed 5.9 cummins, nv4500, 205
86 k30, 89 diesel burb, 76 gmc pathfinder
71 longbed 5.3 4l80
http://67-72chevytrucks.com/vboard/s...d.php?t=522535
v30crewcab is offline   Reply With Quote
