#34 |
![]() Join Date: Mar 2022
Re: Front sway bar diameter
Documenting this for someone else, someday.
I picked up a 1-1/4” (32mm) sway bar off a 1982 C30 regular cab dually. The bushings and mounts I got from Energy Suspension are below with their part number. I am unsure if I will need the “drop” mounts pictured below or not - it depends on the angle of the control-arm-side of the sway bar when I install everything. My C10 has 2.5” spindles and did have 3” springs (until I swapped the drivers side for a 2” spring to get it to sit level). Still don’t understand why….but I guess it’s a thing. |
| Bookmarks |
