#51 | |||||
![]() Join Date: Dec 2009
Re: Wtb axillary fuel tank retaining nuts
So 12" is the measurement on the carriage bolt? Quote:
If so How did they turn out? Quote:
It worked for me.
________________________________________________________________________________________ ____________________________________________ The early bird gets the worm, But the second mouse gets the cheese 85 Chevy K-20 63 Impala (my high school car) http://67-72chevytrucks.com/vboard/s...Crew Cab Build |
#52 |
Here is my best nut for my pattern to make another one.
#53 |
![]() Join Date: Oct 2023
Thanks Getter-Done. I have used Kroil, PB Blaster, WD-40, and now am trying Rustoleum's version of Evapo-Rust. Nut assemblies still fused to the tank. I'll keep at it!
#54 |
As they say.
![]() Patience is a Virtue. Here is my picture of the nut that I saved. I soaked it overnight and was able to break it free from the bolt, once I had it removed out of the Tank. What is this version of Evapo-Rust you speak of? I am always up to try New Stuff.
#55 |
Indeed it is. I've been soaking and cleaning for about a week now. Maybe it just needs another week.
Evapo-Rust is an incredibly effective rust dissolver that is non-toxic enough that you can handle it without gloves and dispose of it down the drain. I used a lot of it when I was working on the rusty bits of my old '57. It isn't cheap, but it can be reused a few times. The rustoleum stuff I found when I was trying to find the Evapo-rust at Lowe's the other day. They don't carry Evapo-Rust (apparently) so I am trying the rustoleum. I'll let you know how it goes. |
#56 |
Has anyone found a source to reproduce the aux tank?
1972 C20 402/TH400/3.54 Highlander 1969 Camaro RS with SS trim, 1967 Camaro RS/SS (sold) ![]() 1983 GMC Sierra Classic 2500 crew cab (sold) 1972 Chevy C10 Cheyenne Super (sold) 1984 Chevy Silverado C20 crew cab (bought new by my uncle, in the family until I sold it) |
#57 |
I had thought of dissecting the tank that was gifted to me and draw up a blueprint.
Then get a Quote to see what it would cost. There is a lot of welding involved and with the price of Sheetmetal, and Sheetmetal brake work in several places, DOM tubes for the thru bolts, pickup tube and tube for filler neck, tube for vent hose and Also, one place that would have to be stamped for the outlet hose. The only Dimension I don't have is the small tab on the side. With this being said, I think the price would be well over $700.oo. I don't think that would be affordable for most. I can be done. ![]() ![]() ![]() Then if there is Shipping involve. ![]() ![]()
#58 |
I agree it would not be inexpensive. I have an original that is basically junk. There is a company in Ft Worth (about a 4 hour drive for me) that makes custom fuel tanks. I emailed them to see if they are interested in building one.
#59 |
I am Interested what they will build one for.
#60 | |
![]() Join Date: Feb 2022
It cleaned, sand blasted, sealed, and painted with perfect result. Lost the finished pic. It was so bad inside I cut two access holes and blasted most of the scale off. Brushed some more and then welded close. Sealed it with a tank restore kit without issue and works great. I even added a bung for a return line so I don't have to worry about over fill on the main. I use electric valves for selection of 3 tanks. The gauge, supply, and return are all switched with a simple rotation of a 3 way rotary switch in the position of the original factory switch. |
#61 | |
Thanks!
#62 |
I seem to have lost the finish pic of the tank in above shots. This is a passenger side tank a fellow forum member gave to me. It had a lower bedside door access filler neck that I converted to the OEM style. The parts for an OEM aux tank is easily revered to passenger side filler neck. You can see in this picture the original fill tube location. I welded shut and added tubes to connect to an OEM style filler neck. I also added return line and provision for sender as the original was void of all that. A word of caution: anyone thinking of welding on a gas tank, be sure all vapor (smell of gas) is gone. It only takes a few drops of gas to turn the tank into a very explosive container ready to light off with a simple spark.
#63 |
I’ll take 4 also
#64 |
The contact info below is copied from Post#29.
There is a picture in post #21. Advanced Machining Solutions (https://www.amsokc.com/) 4703 Enterprise Dr Oklahoma City, OK 73128 405-208-8737 Hope this helps.
| Bookmarks |
