Old 12-31-2025, 11:32 AM   #1
Chaparralman1974
Chaparralman1974's Avatar
Parking Brake Cable - Advice Needed
Good morning everyone and Happy New Year!
I am in the middle of installing a 4" lift on my '67 K20. The rear axle is an Eaton HO52 but I am using 11" drum brakes off of a later model 14 bolt rear end. Since the 11" drums are a bit smaller than the original 12" drums that were on the Eaton the rearmost parking brake cables that run from the backing to the plate are too short. It is now even worse (super tight) after installing the lift blocks. I am looking at Inline tube to see if I can get a custom set of cables made up. I am also going to pick up a set of new cables from a 14 bolt to see if they are a bit longer. However, if I do get new cables made up, how much longer do they need to be? I am thinking about 6" or so, but I have no idea how much slack should be in the cable.
Here are a few pictures of what I am dealing with.
Thanks, Clay
Clayton Sikes
Peoria, Arizona
1967 Chevy K20 "The Town Truck"
Build Thread: https://67-72chevytrucks.com/vboard/...d.php?t=841272
Chaparralman1974 is offline   Reply With Quote
Old 12-31-2025, 03:59 PM   #2
Jason Banks
Jason Banks's Avatar
Re: Parking Brake Cable - Advice Needed
Here are a couple pictures of the cables on my K20. Maybe they will give you an idea how much slack you need?
I wonder if the lift kit people can give you an idea?
Jason Banks is offline   Reply With Quote
Old 12-31-2025, 04:46 PM   #3
Chaparralman1974
Thanks Jason! This helps a lot! Does your still have the original Eaton drums?
Clay
Clayton Sikes
Peoria, Arizona
Old 12-31-2025, 04:59 PM   #4
Jason Banks
Yes, still original drums...
Old 12-31-2025, 05:05 PM   #5
LS short box
Maybe no help but I would check with Lokar to see if they can help.
Old 01-01-2026, 10:28 AM   #6
Chaparralman1974
Jason, could I trouble you for an approximate measurement of the length of your cables? Even with my newer style drums, they still seem way too short. Yours seem to have more than enough slack even if you lifted your truck.
Clay
Clayton Sikes
Peoria, Arizona
Old 01-01-2026, 10:30 AM   #7
Chaparralman1974
I will give them a look see. Thanks!
Clay
Clayton Sikes
Peoria, Arizona
Old 01-01-2026, 12:12 PM   #8
Jason Banks
I can measure them, but I’m standing in the airport and won’t be back until Monday so it would be Tuesday when I do it.
Mine are from in line tube.
Old 01-01-2026, 12:14 PM   #9
Chaparralman1974
No worries at all. I think I am just going to send mine in to inline tube and have them custom make a set.
Have a safe trip man, and Happy New Year!
Clay
Clayton Sikes
Peoria, Arizona
Old 01-14-2026, 03:31 AM   #10
72USA1
72USA1's Avatar
I’m having the same problem with a 6” lift. I haven’t tried it yet but I’m wondering if the frame brackets were removed and install the right bracket to the left side and the left bracket over to the right side. That will give slack to the brake caliper and add length to the forward single cable going to the e-brake pedal. If all that makes sense.
My rides:
Red 67 step side C-10 4x4, Green 68 SWB C-10 4x4, Gold 72 K-5 Blazer 4x4, Blue/White 72 C-20 4x4, White 71 LWB C-10 4x4, Red 70 LWB C-10 4x4, Blue W/White Rally stripe 67 Camaro Z-28, Green 67 Camaro.
72USA1 is offline   Reply With Quote
Old 01-14-2026, 08:36 AM   #11
Chaparralman1974
I ended up contacting Inline Tube to have cables made for it. I am going to just have them add 4" in the middle of the cable to make it work.
Clay
Clayton Sikes
Peoria, Arizona
Old 01-14-2026, 11:55 AM   #12
Sheepdip
Sheepdip's Avatar
Just an example but Lokar makes them, I used them on my 49 Chevy pickup over 20 years ago and they still work great.
Sheepdip is offline   Reply With Quote
Old 01-14-2026, 01:12 PM   #13
dagnabbitt
dagnabbitt's Avatar
Clay
One of the amusing things about my 72 build is/was that during my search for the right parking brake parts, I found that the PO just welded a couple cables together to make the length correct.
It actually works fine, but I like your plan better.
DAVE
Edmonton, Alberta
1959 Apache
1967 K20
1968 C20
1970 C10
1972 GMC 2500
1981 C10
