Senior Moment
![]() Join Date: Mar 2002
Anybody running ITB/ Stacks on there LS
Anyone running individual throttle body’s / Stacks on there LS.
1970 CST LS 1 6 speed Ford 9 inch Detroit Tru Track, Dakota Didgital, Vintage Air, QA1 Coil Overs Front & Rear Lots of FUN 2013 GMC PU, Oldest Son 71 GMC LWB. QA1 Suspension, Angry SB. Youngest Son 2017 Toyota SUV Daughters car 2018 Traverse , Wife’s Ride Pittsburg Ca 94565 Last edited by 1970 CST Short Wide; 12-30-2025 at 01:25 AM. |
Senior Moment
Re: Anybody running ITB/ Stacks on there LS
Nobody?? Anybody know anything about running Stacks ???
1970 CST LS 1 6 speed Ford 9 inch Detroit Tru Track, Dakota Didgital, Vintage Air, QA1 Coil Overs Front & Rear Lots of FUN 2013 GMC PU, Oldest Son 71 GMC LWB. QA1 Suspension, Angry SB. Youngest Son 2017 Toyota SUV Daughters car 2018 Traverse , Wife’s Ride Pittsburg Ca 94565 |
#3 | |
![]() Join Date: Mar 2022
If you’re after cool looking & different….have at it. |
I think they look very cool. But and you know the but was coming I would really be concerned about tech support and some one who can tune it.
I would ask the same question over on LS1tech.com. |
#5 | |
Senior Moment
I should have done it back when I had the BB in the Truck
Senior Moment
Ok. So I talked to my Tuner and he said No Problem, He’s done a few. Sooooo
I ordered from Redux Racing in Australia. They showed up today and after mock up assembly the Manifolds are going for Gloss Black Powder then On They Go At 71 years of age this is like a Bucket List item for Me. Can’t wait to get the on. Will post more as i Progress in
#7 | |
Individual runner intakes eliminate the problems that big cams cause- reversion during overlap at low rpm pumping back into the intake plenum which screws up the air/fuel charge for the next cylinder's intake stroke- that's why big cams chop, it's a misfire caused by reversion havoc on the air/fuel ratio in the plenum. On my VWs I have run quad Dellorto carbs on individual runners to get one barrel per cylinder and they idle dead smooth even with 300*+ adv duration cams, and pull hard from idle. That exact same cam with a plenum intake would chop hard and had no power off idle until rpm was high enough that the intake charge had enough momentum to overcome reversion. The difference in driveability and lower rpm torque in normal driving is huge, and the throttle response is unmatched by anything else. On a revision of one of my VW engines, I actually went with an even bigger cam, bigger carbs, and heads with bigger ports/valves to take away some of the low rpm tq and response so it would be easier to drive smoothly around town, it had too much throttle response before. Size the throttle bodies adequately and they make just as much power at upper rpm as anything else on a street engine. I'm collecting parts to run Webers on an individual runner intake for my '66 now, and have a pair of sidedraft Dellortos on my autocross car. Once you experience them you want them on everything.
Project Goldilocks '66 C10 Short Fleet BBW Build '65 C10 Highly Detailed Stock Restoration Thread '78 Camaro Targa Roof Build '55 International Metal/Body/Paint Work '66 F100 Full Rotisserie Restoration '40 Packard 120 Convertible Coupe Restoration How To Restore and Detail an Original Gauge Cluster How To Detail Sand Body Panels, Edges, Corners, Etc |
| Bookmarks |
