Old 01-05-2026, 03:20 PM   #1
tdangle
tdangle's Avatar
body molding
I'm working on refreshing my OG upper and lower molding. Has anyone used 2 sided tape in lieu of the clips?
Terry
1970 Custom Camper/C20 , GM Crate 350/7004R, Dana 60, factory AC
tdangle is offline   Reply With Quote
Old 01-07-2026, 03:09 AM   #2
vics stuff
Re: body molding
I think LMC just had a video on here on installing trim without clips and it was real informative. Maybe someone here can elaborate.
Vic
vics stuff is offline   Reply With Quote
Old 01-07-2026, 12:39 PM   #3
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
Re: body molding
Personally I'd avoid that, especially at the doors, and definitely for the short pieces that would never involve tape - Same the top fender, which takes none. IMO, no more than 1/3rd of the clips per piece should be tape, if any.
Tony 1971 C10 Custom Deluxe SWB 402/400TH A/C
I developed an assembly information kit for restoring my truck from nuts and bolts. It's written in Assy. order, short & simple, packed with all OEM hardware ID; castings; part ID; 100s of part numbers; wiring simple - Resource, and trivial too.
Much info. applies to all 67-72 GM, A/C vehicles, esp. trucks W/O saying. Full search ability, including to 700+ images of illus., parts, charts, Assy., points of interest, cab, bed, & front clip cart plans- Specials and cores were serviced out and R excluded e.g. front/rear glass, body/paint, engine core, rebuilt hinges, steering box, trans, etc.
The project was in-line with long former professions developing process, policy, specs, demo, written for novices, admin., policy, engineers, development, systems & test - Public & govt 2, gross. Sell soft copy cheaply, PM if interested.
Build thread:https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is online now   Reply With Quote
Old 01-07-2026, 06:42 PM   #4
7D2N
7D2N's Avatar
Re: body molding
I installed my lower trim kit with trim tape and it stuck great. Its very hard to remove when it don't line up right.
Just for the fun of it
7D2N is offline   Reply With Quote
Old 01-07-2026, 11:23 PM   #5
71CHEVYSHORTBED402
Re: body molding
. Sure can be, a few do-overs at the doors here. WD-40, hair dryer, and the right clean plastic knife makes it an easy chore.
Old 01-08-2026, 01:26 PM   #6
Casper42
Casper42's Avatar
Re: body molding
if you use any tape, I highly suggest preping the surface with 3M Tape Primer #94 first. https://www.3m.com/3M/en_US/p/d/b40065491/
'72 C10 Cheyenne SWB North Carolina kept for 50 years, 75k original miles, Medium/Hawaiian Blue paint, 3 owners - one for 40 years & garaged kept. Original: sheetmetal, undercarriage, moldings, glass, immaculate unrestored bed.
New - rebuilt engine at 65k in 2015, one frame-on respray in 2010, front bumper, blue houndstooth seat, carpet, 8 inch rally wheels on 275-60R-15, LED lighting. - Semper Paratus!
Casper42 is online now   Reply With Quote
Old 01-08-2026, 06:01 PM   #7
7D2N
7D2N's Avatar
Re: body molding
Yes, prep is important. I used 3M trim tape and this is how I attach mine.
Old 01-09-2026, 05:10 PM   #8
howzzzit
howzzzit's Avatar
Re: body molding
Is the tan colored plastic (I assume plastic) tucked under the flange of the trim? Taped underneath and how thick and type of material? Some plastics just won't bend. Thanks.
howzzzit is offline   Reply With Quote
Old 01-09-2026, 06:54 PM   #9
Extended Power
Extended Power's Avatar
Re: body molding
I used 1/8” thick Lexan and cut it about an inch short of each end for length on each piece.
Also used the special 3m double sided tape in 1/16” thickness.
Bought several rolls because I did the entire length of the trim, end to end, top and bottom and both ends.
Yours looks awesome!
When I wrapped the wood grain trim material around the ends, I taped it down with Gorilla tape so it would never start to lift.
I also used the factory trim attachment hardware on the top trim, front of the fenders...the little wedge pieces. And the trim hardware on the door ends. Every other trim hole was filled so I used the two sided tape and Lexan.
Yes, it is a very tight fit and does not slide around when it’s tucked under the flange trim.
I used the 3m tape the is 1/16” thick. If for some reason the trim hits the body of the truck and the tape doesn’t stick, just double it up...it’s only 1/16”.
"If it ain't broken, fix it 'till it is!"
Extended Power is offline   Reply With Quote
Old 01-10-2026, 07:08 PM   #10
71CHEVYSHORTBED402
Re: body molding
Looks real good
