| View Poll Results: Should I paint the top of the roof White or Green (see post #71 for pics of both) | |||
| Green roof top with white pillars |
5 | 50.00% |
| White roof top with white pillars |
5 | 50.00% |
| Voters: 10. You may not vote on this poll | |||
#39 |
Re: Project Large Marge - Going Full Tilt
When I got home, I started cleaning it up, and I noticed all the bolts for things like the valve cover and the exhaust manifold were only finger tight. Nothing was torqued properly. This was when I decided I would try to see if the thing would spin. I could get it to turn ¼ turn, but that’s it. It wasn’t totally locked up, but it was pretty close. Also for you Cummins guys, have you ever seen a blue one before? it was a first for me. it does appear to be a factory paint job. Just the gear case cover and the valve ccovers are blue. The rest of the engine is black.
65 short step rebuild thread http://67-72chevytrucks.com/vboard/s...d.php?t=621399 60 apache 4x4 build thread http://67-72chevytrucks.com/vboard/s...d.php?t=824325 Large Marge Cab over build https://67-72chevytrucks.com/vboard/showthread.php?t=857842 |
| Bookmarks |
