Old 03-02-2023, 11:33 PM   #1
Already Gone
70+ ( Old Skool Club )
Already Gone's Avatar
1967-1972 Chev/GMC Truck Assembly Manual
So finally got an official 67-72 Factory Assembly manual. Its thick and loaded with info but finding the specific info you want is very time consuming as there is no index of whats where in it. Anyone have any info or ideas to find something quickly in the manual.
1992 K1500 GMC Suburban
" In the end, we only regret the chances we didnt take "
" Time is the only currency we spend without knowing the balance, use it wisely ." ..
Old 03-02-2023, 11:41 PM   #2
Steeveedee
Ram-A-Lam-A-Ding-Dong
Steeveedee's Avatar
Re: 1967-1972 Chev/GMC Truck Assembly Manual
There is an index circulating around here, somewhere. I downloaded it years ago, but can't find the link, now. I don't think that a spreadsheet will load as an attachment, but I'll give it a shot.
Guess not. Somebody else should be able to load it?
~Steven
Simi Valley, CA
Old 03-03-2023, 01:15 AM   #3
FirstOwner69
FirstOwner69's Avatar
This?
https://docs.google.com/spreadsheets...FWQ/edit#gid=0
Jim
FirstOwner69 is offline   Reply With Quote
Old 03-03-2023, 01:27 AM   #4
Steeveedee
Steeveedee's Avatar
^ YESSS! I have it, but couldn't figure on how to load it up from my computer. Thanks for finding it. The OP should be happy.
~Steven
Simi Valley, CA
Old 03-03-2023, 02:04 AM   #5
D-n-Tyke
Can someone explain how to read that. I don't understand what all the columns with the x's on the right.
D-n-Tyke is offline   Reply With Quote
Old 03-03-2023, 11:30 AM   #6
pjmoreland
pjmoreland's Avatar
Member CS1972 created a PDF version of the factory assembly manual that is free to download. It allows you to do text searches, which makes it way easier to find stuff.
https://67-72chevytrucks.com/vboard/...d.php?t=833705
pjmoreland is offline   Reply With Quote
Old 03-03-2023, 12:24 PM   #7
Yamariv
Yamariv's Avatar
Just downloaded the manual but it seems the columns on the index don't match. How do you read the index?
1971 Chev C10 - 250ci L6 w/3 speed on the floor
Upgrades: Power Steering
3 Core Radiator
7 Hole Gauge Cluster
Power Brakes (Incoming!!..)
1971 350 (Incoming!!..)
Yamariv is offline   Reply With Quote
Old 03-03-2023, 12:31 PM   #8
LockDoc
The Older Generation
LockDoc's Avatar
You should have bought the CD. You can look up anything you want on it.... It has a search function.
https://www.classicparts.com/1967-72...fo/04%2D631CD/
https://www.americanclassic.com/1967...fo/04%2D631CD/
LockDoc
Leon
Old 03-03-2023, 12:34 PM   #9
72SB
+1 on the FSM being essentially a brick. I also got a copy of the spreadsheet from Steve and do not see how it correlates with anything
These repop FSM apparently do not have index. Same issue with my 1st gen Camaro
72SB is offline   Reply With Quote
Old 03-03-2023, 12:37 PM   #10
jeffahart
jeffahart's Avatar
Steeve,
You see "doc.google.com" in the URL. You need to logon to google with your account. Then you can select "File" in the spreadsheet menu and select "Download". you can download as .xls OR .pdf. The options are locked until you login to google.
j
White K20
jeffahart is offline   Reply With Quote
Old 03-03-2023, 12:48 PM   #11
72SB
While the images and info in the Repop FSM is valuable, without being able to have a readable index it is very tedious to find what you need. It has no page #'s to cross reference using an auxiliary spreadsheet index is...well.
The Haynes or Chilton manuals while not as detailed as an FSM, for me usually give me enough 411. The Haynes one is around $25 available at places like Amazon.
Fortunately for any 50+ year old vehicle, there are forum specific sites like this with very helpful members.
Old 03-03-2023, 02:02 PM   #12
Steeveedee
Steeveedee's Avatar
Originally Posted by jeffahart View Post
Steeve,
j
Thanks, but I downloaded it quite awhile back. I didn't remember where from.
~Steven
Simi Valley, CA
Old 03-03-2023, 04:07 PM   #13
jeffahart
jeffahart's Avatar
Soory about that. I see you were trying to make it available to OP.
j
White K20
Old 03-05-2023, 05:48 PM   #14
Already Gone
Thanks for all the responses.
Old 03-05-2023, 06:59 PM   #15
Yamariv
Yamariv's Avatar
Can someone please explain how the directory works for the assembly manual? Nothing seems to line up, am I doing something wrong?
3 Core Radiator
Old 03-07-2023, 02:25 PM   #16
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
The assembly pages are often random, and repetitive.
I have the index in a Word doc if needed. You get to spend perhaps an hour numbering every other page for 1065 pages, yikes.
LockDoc
Wow, I didn't know of that.
Tony 1971 C10 Custom Deluxe SWB 402/400TH A/C
I developed an assembly information kit for restoring my truck from nuts and bolts. It's written in Assy. order, short & simple, packed with all OEM hardware ID; castings; part ID; 100s of part numbers; wiring simple - Resource, and trivial too.
Much info. applies to all 67-72 GM, A/C vehicles, esp. trucks W/O saying. Full search ability, including to 700+ images of illus., parts, charts, Assy., points of interest, cab, bed, & front clip cart plans- Specials and cores were serviced out and R excluded e.g. front/rear glass, body/paint, engine core, rebuilt hinges, steering box, trans, etc.
The project was in-line with long former professions developing process, policy, specs, demo, written for novices, admin., policy, engineers, development, systems & test - Public & govt 2, gross. Sell soft copy cheaply, PM if interested.
Build thread:https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline   Reply With Quote
Old 03-07-2023, 03:20 PM   #17
howzzzit
howzzzit's Avatar
http://67-72chevytrucks.com/vboard/s...d.php?t=558016
Has everything including a search feature. Use it all the time.
howzzzit is offline   Reply With Quote
Old 03-07-2023, 07:05 PM   #18
71CHEVYSHORTBED402
Some reason it planted a bug in my last computer. I didn't load anything but the link, and I had McAfee. Maybe my computer, maybe the link fixed, either way I avoid it.
Old 01-16-2026, 08:25 PM   #19
mr48chev
mr48chev's Avatar
LockDoc
If you don't have a computer in the garage/shop the CD means that you have to run back to the computer to look at the screen every time rather than opening the book next to the truck. I run into that with the CD manual for my HHR.
My ongoing truck projects:
Old 01-16-2026, 09:15 PM   #20
G-749
Active Member
Talking Re: 1967-1972 Chev/GMC Truck Assembly Manual
Bought this back when I got the Longhorn, be 3 yrs in February, also bought 4 colors standard sticky notes , black sharpies , couldn't work on truck once I started the radiation treatment, looked at every page, anything that in anyway was for a 1970 C 20 Longhorn. Got a color sticky note and a hand written title , took a while couple months prolly more .
But now I can access anything at all that relates to my truck , and don't have to spend hours looking through unnecessary pages of information that doesn't apply to my truck.
Good luck on all your projects.
70 C 20 Longhorn PS , PDB, Dealer installed AC, 700 R4, Dual battery, original TAX 350 motor, 3rd owner truck.
71 C 50 292 4sp 2sp vacuum operated rear end 8 x 12 flat bed.
22.5 Goodyear radial$ n Wheels Now rim$
86 Grand Wagoneer " Saggy Waggy " Jeep = Just Empty Every Pocket $$$ currently in another shop
G-749 is offline   Reply With Quote
Old 01-17-2026, 01:39 AM   #21
LockDoc
LockDoc's Avatar
I know what you mean. That is why I'm in such good shape.....
I now have a computer in the shop.
Leon
