Old 01-17-2026, 03:16 PM   #1
MikeB
MikeB's Avatar
Best paint for bare steel A/C brackets
I have a some fairly clean bare steel A/C compressor brackets I need to paint. How about some tips on paint types and brands that have held up well for you? Direct-to Metal top coats, primer + top coat, etc.
Mike
1969 Custom/10 LWB -- owned for 37 years. 350/TH350, 3.08 posi, recent AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. Hedman stainless headers. Old Air installation in progress.
1982 Custom Deluxe 10 SWB -- converted from 250-six to roller cam 350 w/ Vortec heads -- sold
1981 C10 Silverado LWB, 305, TH350C -- sold, but wish I still had it!
1969 C10 (not the current one) which I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming.
Retired as a factory automation products salesman.
Worked part-time over the years for an engine builder and a classic car repair shop.
Member here for 26 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then!
MikeB is offline   Reply With Quote
Old 01-17-2026, 08:16 PM   #2
basketcase
basketcase's Avatar
Re: Best paint for bare steel A/C brackets
I have gotten good results with the Rustoleum paint and primer in one can. I did some a/c and p/s brackets a few years ago and they still look fresh. Wipe them down thoroughly with a pre paint cleaner and scuff the parts with a 3M red pad so the paint can get a good bite, then wipe down again before spraying. Spray when the parts are in the recommended air temperature range and you will get a nice finish. But beware. I have had problems with Rust oleum running out of propellant lately when the can was still half full. I read that this is a problem in that brand but ignored it.
The last time I sprayed small black parts and brackets I used Behr Premium paint+primer from Home Depot. It sprays nicer than most and leaves a nice finish. Also. the can I'm using now feels empty but is still spraying.
'69 swb stepside in progress.
'59 Corvette lifetime project
basketcase is offline   Reply With Quote
Old 01-17-2026, 11:02 PM   #3
MikeB
MikeB's Avatar
Is this what you used?
https://www.homedepot.com/p/BEHR-PRE...2144/310275636
Mike
Old 01-17-2026, 11:05 PM   #4
Sicklajoie
The Niner
Sicklajoie's Avatar
Not interested in powder coating them?
"A good racer is one whose head is in communication with his balls." - Richie Evans
1970 C/20 - 402/TH400/3.54s - 74K miles
2003 GMC Sierra 2500 - Wheatland Yellow
Niner Progression Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=697183
Classic Trucks article: https://www.motortrend.com/features/...et-c20-driven/
Sicklajoie is offline   Reply With Quote
Old 01-17-2026, 11:13 PM   #5
MikeB
MikeB's Avatar
Definitely a good idea, but a little expensive. Got a quote from a local shop to do a spare tire carrier. $75, but that did include bead blasting.
Maybe I should call them Monday.
Mike
Old 01-17-2026, 11:18 PM   #6
dagnabbitt
dagnabbitt's Avatar
I personally like this stuff for everything under the hood. Really lays down and looks nice.
https://www.amazon.ca/Dupli-Color-DE.../dp/B000GKAZEK
DAVE
Edmonton, Alberta
1959 Apache
1967 K20
1968 C20
1970 C10
1972 GMC 2500
1981 C10
Old 01-17-2026, 11:31 PM   #7
MikeB
MikeB's Avatar
Do you use it over bare metal, or with primer?
Mike
Old 01-17-2026, 11:36 PM   #8
dagnabbitt
dagnabbitt's Avatar
I 've used it on bare metal, but for a good finish I'd use their primer too. They also have a ceramic enamel satin clear coat to put over top that I've used.
https://www.amazon.ca/Dupli-Color-DE...001DKUTLG?th=1
DAVE
Edmonton, Alberta
1959 Apache
1967 K20
1968 C20
1970 C10
1972 GMC 2500
1981 C10
Old 01-17-2026, 11:59 PM   #9
GSP7
GSP7's Avatar
since you have to ask on a internet forum..... por15.....
'81 K20 Silverado , '99 Dodge Cummins 4x4, '05 Dodge Cummins 4x4,
No Snivelers
"No Lowballers, I know what I got"
GSP7 is offline   Reply With Quote
Old 01-18-2026, 12:48 AM   #10
basketcase
basketcase's Avatar
Originally Posted by MikeB View Post
yes,
Old 01-18-2026, 12:26 PM   #11
raggedjim
raggedjim's Avatar
Gregski did a couple spray bomb comparisons in the past.
https://67-72chevytrucks.com/vboard/...ighlight=paint
raggedjim is offline   Reply With Quote
Old 01-18-2026, 12:53 PM   #12
KMC3420
KMC3420's Avatar
For adhesion I would sand with 80 grit and then epoxy primer, if you can’t sandblast the brackets. I typically sandblast and epoxy. Even if you use rattle can, I would use a primer first. As the brackets sit now, you can paint them, primer first, and then color. However, it might turn into they look good, but the paint will come off by simply scratching with your fingernail. You likely already know that, but the paint has to have some kind of tooth to hold onto, sanding or blasting.
Keagan
68 SWB C-10 original 350 A/C 503 Mean Green
KMC3420 is offline   Reply With Quote
Old 01-18-2026, 01:18 PM   #13
MikeB
MikeB's Avatar
Good info, because I was thinking about using a scotch brite pad, which might not be coarse enough. Although 80 grit seems a bit too coarse.
Many years ago I used PPG greenish-gray epoxy primer on a rusty pickup bed that had been wire-brushed and coarse-sanded to knock off the loose rust. Followed that up with their DP primer. Then had a shop paint the entire truck with DuPont Centari enamel. 20+ years later there was still no rust peeking through, except in the areas that had been scratched by hauling stuff. Of course, similar products would cost 5-10 times as much these days.
Mike
Old 01-18-2026, 01:51 PM   #14
KMC3420
KMC3420's Avatar
Yep, epoxy primer from a spray gun being epoxy plus activator gives the best chance of longevity. Epoxy is my go to and is tough. You nailed it on the head though, the cost of everything is crazy these days. $60 for a quart of epoxy and activator. There are for sure cheaper routes, but it all depends on if it is just a quick paint it and get it installed or if it needs to be as nice as possible.
Keagan
Old 01-18-2026, 02:38 PM   #15
DA71Grande
DA71Grande's Avatar
I’ve had good results with either of these, both seem to hold up very nicely
Doug
71 Sierra Grande C25
16 Sierra 2500HD All Terrain
23 Chevy Tahoe Z71
https://paypal.me/digdug7131?locale.x=en_US
DA71Grande is offline   Reply With Quote
Old 01-19-2026, 11:54 AM   #16
Mid-Pack
Mid-Pack's Avatar
Dupli-Color Self-Etching primer and Engine Enamel, when painting bare metal.
Mid-Pack is offline   Reply With Quote
Old 01-19-2026, 12:30 PM   #17
A1971Blazer
A1971Blazer's Avatar
Eastwood and others have a 2 part epoxy primer in a spray can. You activate it with a punch valve on the bottom of the can.
I have used it several times.
The only drawback is that it's good for only 36 hours after activation.
If you only need part of the can, it wastes the rest.
It's a little pricey too.
1967 C10 Step side
1968 C10 Step side
1970 Chevrolet K/5 Blazer
A1971Blazer is offline   Reply With Quote
Old 01-19-2026, 01:28 PM   #18
425HP409
425hp409
425HP409's Avatar
I have been using Napa Self Etching Primer #MS 7220 and Napa Chassis Black #MS 7243 for years. Everything from inner fenders, under hood metal, radiator support, brackets etc. for decades. It gives a nice semi gloss finish and holds up real well, for years. There is a lot of paint in each can and it lays down nice with multiple coats.
primer $14.41 list
paint $12.35 list
Charles
68 SWB, Dad bought new, now 396 & factory ac
64 Impala SS, 409 425HP, 4 speed AC
64 Bel Air Wagon, 400 Small Block
57 Bel Air all original 283 w/Factory Air
77 GMC Sprint, 454/425HP
67 Oldsmobile 442, all original
425HP409 is offline   Reply With Quote
Old 01-19-2026, 02:30 PM   #19
MikeB
MikeB's Avatar
I don't know how hot this bracket will get, but I may need to choose a paint that can withstand more than 250 degrees. The compressor will hide only the front half of the bracket. Not that my engine compartment is a showpiece!
Mike
Old 01-19-2026, 02:42 PM   #20
Mid-Pack
Mid-Pack's Avatar
Here`s a little info. I have the same brackets and they still look like new.
https://www.duplicolor.com/en/produc...t-with-ceramic
Old 01-19-2026, 02:49 PM   #21
howzzzit
howzzzit's Avatar
Rustoleum etching primer. I don't think anything black was factory semi-gloss. Could be wrong. I used Krylon RTA 9203 semi flat. It has a light sheen like original parts. Another light sheen paint is Rustoleum in canyon black. I've used both and they are very close. Rustoleum a better paint in my opinion. Cheap enough to sample and locally available.
howzzzit is offline   Reply With Quote
Old 01-19-2026, 03:08 PM   #22
MikeB
MikeB's Avatar
Did you also use the primer?
Mike
Old 01-19-2026, 04:49 PM   #23
Mid-Pack
Mid-Pack's Avatar
Yes, I did. Give the parts a scuff and apply thin coats.
Dupli-Color does offer a low-gloss engine enamel, if that`s your flavor.
Old 01-19-2026, 05:10 PM   #24
Rust_never_sleeps
Rust_never_sleeps's Avatar
I use Black Duplicolor rust fix under the hood, but my goal is for new parts to not look new and old parts to not rot off
1970 C10 Custom longbed 350/350
“Carburetors are forgiving, timing is not” — Thunderhead289
Rust_never_sleeps is offline   Reply With Quote
Old 01-19-2026, 05:36 PM   #25
HO455
HO455's Avatar
I believe that the question should be, what is the best process to paint the brackets. The greatest paint in the world will fail with poor preparation.
Personally I have found cleaning the bare metal with wax and grease remover after scuffing with a red Scotchbrite is important. I follow with 2 coats of a quality self etching primer like Rustolem. Then top coat with a quality color of choice.
Now days I avoid the paint and primer in one products as I have found them to scratch easily.
I've used epoxy primers for larger projects but they require a higher level of PPE to use safely (unless your brushing it on) and for the type of project your looking at I haven’t found self etching primer to be substandard or lacking in performance. And epoxies usually have more restrictive coating and cure temperature ranges.
As always this is just my opinion which along with a sawbuck will get you a steaming hot cup of Joe just about anywhere.
RIP Bob Parks.
