Old 09-27-2025, 10:12 PM   #1
skokie
skokie's Avatar
16 inch rims for a 68 C10 6 lug
Hey!
I am shopping around for tires and rims. Currently have 15x7s on the truck now and was thinking about going to 16s. Any suggestions on where to get some good rims?
RIP to my son Dylan. 5/17/2002 - 8/18/2018
If you want to know more about rare forms of pediatric cancer or if you want to help fund pediatric cancer research, please check out the website for the non-profit I started.
https://slothforpedcancer.org
68 build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=223234
skokie is offline   Reply With Quote
Old 09-27-2025, 10:35 PM   #2
Re: 16 inch rims for a 68 C10 6 lug
Depending on what you want. Just about any 6 lug will work.i used some old 16x8 wagon wheels that I ran on my 02 silverado. I use a spare from my 2010 tacoma 16x6.5. I even tried the 17x8 lexus gx 470 wheels that i am using on my tacoma. .
Old 09-28-2025, 01:08 PM   #3
skokie
skokie's Avatar
Whats the bolt pattern for a 6 lug C10?
Thanks!
68 build thread
Old 09-28-2025, 02:53 PM   #4
6x5.5 or 6x139.7 for the metric side. Only thing to watch on some later model wheel is center bore size, especially on allot rims. Not sure of actual measurement, but you'll be able to tell. I know most gm, ford, and dodge of the 60s thru 90s, maybe later should fit. Most tacomas, tundra and lexus gx model with 6 lug have a large enough center bore
Old 09-28-2025, 05:15 PM   #5
72c20customcamper
72c20customcamper's Avatar
I ran M/T wheels off my Tacoma for a year or so .
Mark
1969 AMX ,
1968 c20 stepside ,85 K20
1977 Suburban sold
68 anniversary.
Old 12-23-2025, 02:57 AM   #6
skokie
skokie's Avatar
My 68 C10 has drums on all 4 corners. I have a 01 GMC Sierra and it has 6 lug rims. Would a set of rims from a 99-07 GMC Sierra work? What about back spacing?
Thanks!
68 build thread
Old 12-23-2025, 03:16 AM   #7
kolle_hond
I used the 16 inch wheels off a 2012 Chevy Trailblazer, but they had a negative offset, so I had some very expensive 90mm spacers made. I was quite happy with the result at the time.
1970 C10 (undergoing 350 swap) 3-speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=650480
kolle_hond is offline   Reply With Quote
Old 12-23-2025, 12:22 PM   #8
skokie
skokie's Avatar
Does anyone know what the offset will be for a 4 way drum setup for a 68 C10?
68 build thread
Old 12-24-2025, 03:21 AM   #9
kolle_hond
Ideally you want the offset to be zero, or negative (more towards the outside).
I believe my wheels have either a +35mm or +50mm offset (placing them towards the inside)
The tyres are relatively narrow (245/70R16) compared to what most people who change the wheels run, and still rubbed the wheel well in the front when I turned the steering wheel too far, therefore the spacers.
My truck is not running at the moment (long story), and the rotors on the front are about 10mm more towards the outside than stock drum rotors, but look at the difference between the front wheel with no spacer at the moment vs the rear wheel with a 90mm spacer.
Old 12-24-2025, 02:47 PM   #10
BRL
BRL's Avatar
I like those Chrome wheel well flares.
BRL is offline   Reply With Quote
Old 12-24-2025, 07:34 PM   #11
skokie
skokie's Avatar
This is what I have on my 01 GMC Sierra. Was looking for something like this for the 68 C10. https://www.ebay.com/itm/16799292359...Bk9SR7SararqZg
68 build thread
Old 12-24-2025, 07:47 PM   #12
'68OrangeSunshine
'68OrangeSunshine's Avatar
I had some 16x8 aluminum rims my friend kicked off his '99 K/1500 GMC Suburban. [He didn't like the look -- ''too Blingy''].
To mount them on my '71 GMC Jimmy [w/ rear drum brakes], I had to install 2'' wheel adaptors. Six lug. They bolt onto the axles, then the rim is bolted onto the adaptor.
Worked fine, until I heard a weird metallic ticking in my drivetrain. Paranoid, I pulled the adaptors and installed the old 33x12.50x15LT ''meats'' from before. Ticking however, was from my front Carden prop shaft disintegrating. Adaptors, Bling rims and tires were fine.
[I have since mounted the bling rims and 235/75/R16 tires on my 2003 Tahoe.]
'68OrangeSunshine is online now   Reply With Quote
Old 12-26-2025, 10:49 PM   #13
Mike C
Mike C's Avatar
I tried a set of OBS 6 lug wheels on my 69 short step and the center hole is not big enough for the pilot to go through. So Toyota may work, but the GM wheels didn’t for me.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 01-19-2026, 07:30 PM   #14
skokie
skokie's Avatar
Thanks for all of the information. Can anyone suggest a place to pick up 4 16x7 rally rims for a truck with drum/drum setup?
68 build thread
Old 01-19-2026, 08:08 PM   #15
Sicklajoie
The Niner
Sicklajoie's Avatar
Curious if these would work.
https://www.etrailer.com/Trailer-Tir...LEbsOL5AUOEAuT
"A good racer is one whose head is in communication with his balls." - Richie Evans
1970 C/20 - 402/TH400/3.54s - 74K miles
2003 GMC Sierra 2500 - Wheatland Yellow
Niner Progression Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=697183
Classic Trucks article: https://www.motortrend.com/features/...et-c20-driven/
Sicklajoie is offline   Reply With Quote
Old 01-20-2026, 04:07 AM   #16
Rust_never_sleeps
Rust_never_sleeps's Avatar
Take a look on FB Marketplace. Rallies are fairly common in the Bay Area
AFAIK, drums always fit, it's the disks that are a PITA
1970 C10 Custom longbed 350/350
“Carburetors are forgiving, timing is not” — Thunderhead289
Rust_never_sleeps is offline   Reply With Quote
