Old 01-21-2026, 10:00 PM   #1
IT Cowboy
IT Cowboy's Avatar
What type of air-cleaner is this and what for?
In searching for air cleaners I have seen a few pics of the original large OE air cleaners with the snorkel / horn on them and a smaller lid in it usually chrome that just covers the filter. The one in this pic is all I could find right now. Is this a new style, mod thing or is this an old concept and thing that is making a comeback. Does it have a purpose like keeping the incoming air cooler and acting as a heat shield?
Also which way should the intake snorkel / horn face on a BB OE air cleaner. I have seen both but the repair manual and other pics it is pointing towards the passenger side
1972 C10 Custom Deluxe Highlander 402
Freedom isn't safe, it requires you to take responsibility for your own life, your own safety, and your own success. It carries with it the possibility of failure and the understanding that you're working without out a safety net. If you give the state the responsibility for any of these you also give up the freedom that accompanies the responsibility.
IT Cowboy is offline   Reply With Quote
Old 01-21-2026, 10:44 PM   #2
truckster
truckster's Avatar
Re: What type of air-cleaner is this and what for?
That's an interesting air cleaner. I doubt it would draw any air through the horn.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson
1972 K/5 Blazer CST 4WD
1963 Corvair Monza Spyder Turbo convertible
1995 Camaro Z/28
truckster is offline   Reply With Quote
Old 01-21-2026, 11:23 PM   #3
geezer#99
geezer#99's Avatar
Those had a sealing rubber ring around the outside.
The seal contacted the under hood on a cowl induction hood.
Like on a chevelle.
https://www.musclecarcentral.com/197...p/air-4012.htm
geezer#99 is online now   Reply With Quote
Old 01-21-2026, 11:35 PM   #4
geezer#99
geezer#99's Avatar
The snorkel position is dependent on the little bump out on the air cleaner. That bump out is for distributor clearance. On the pic the bump out is on the left. The snorkel would point to the passenger side.
Old 01-22-2026, 05:16 PM   #5
LS short box
IMO that was fairly common mod back in the day to get more air in the engine. I would bet the lid is a aftermarket lid
Sometimes folks would take the stock lid and just turn it upside down and put it back on for the same affect.
Old 01-22-2026, 10:55 PM   #6
SRU1436
I currently do that.
SRU1436 is offline   Reply With Quote
Old 01-22-2026, 11:41 PM   #7
Mike C
Mike C's Avatar
That is a cowl induction air cleaner as mentioned above. But it is missing the top piece that the rubber seal attaches to. It is near identical to the one on my 69 Camaro.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 01-22-2026, 11:53 PM   #8
Shark_13
I think it's been proven to add HP... (Seriously)
Old 01-23-2026, 12:12 AM   #9
IT Cowboy
IT Cowboy's Avatar
An naturally aspirated gas engine is a giant air pump = more air in more power out and that is of course how blowers work by forcing air in.
I have a couple of stickers that add at least .005 hp
Old 01-23-2026, 12:33 AM   #10
Steeveedee
Ram-A-Lam-A-Ding-Dong
Steeveedee's Avatar
Pretty, but not a power adder.
~Steven
Simi Valley, CA
Old 01-23-2026, 06:27 AM   #11
Already Gone
70+ ( Old Skool Club )
Already Gone's Avatar
I bought the pictured air cleaner for my 4BBL QJet 350 when first got my truck 10 years go. The spec is for a 1972 Z28 Camaro and it fits the truck perfectly. I haven't looked in a while but could be still available. I believe I bought it from Summit. I put the decal on it so matches what was on the factory one. i just liked the look of the same size dual snorkels.
1992 K1500 GMC Suburban
" In the end, we only regret the chances we didnt take "
" Time is the only currency we spend without knowing the balance, use it wisely ." ..
Old 01-23-2026, 11:42 PM   #12
Mike C
Mike C's Avatar
It is when properly ducted to a cowl induction hood. My Camaro went from 13.20’s to 12.70’s in the quarter with the cowl induction setup. This in Texas in the summer when ambient temps were in the low 100’s.
44 Willys MB
52 M38A1
64 Corvette Coupe
Old 01-23-2026, 11:43 PM   #13
Mike C
Mike C's Avatar
It is still available. I purchased one for my 427 that is going into my ‘69 short step. It was for 70-72 LT-1 Z/28’s
44 Willys MB
52 M38A1
64 Corvette Coupe
Old 01-24-2026, 12:20 AM   #14
Steeveedee
Steeveedee's Avatar
In this case, yes. Buick made a kit for cold air induction from the cowl to the air cleaner in '68. Not as good as cowl induction, but good for a solid .1 in the 1/4. But the air cleaner pictured isn't configured like a cowl induction.
~Steven
Simi Valley, CA
