Old 04-11-2021, 06:20 PM   #76
cwcarpenter98
cwcarpenter98's Avatar
Re: 1966 GMC K10 Suburban Project
Those parts cleaned up nicely!
Blasted and powder coated?
Christian Carpenter
Overdrive wiring here
1981 C10 - Penny 350, Saginaw 4 speed
Old 04-14-2021, 08:12 PM   #77
aotte1
Ol Blue K20, cwcarpenter98, thanks for comments and question. The parts cleaned in media blaster with garnet grit 120, also available in other grades. The finish is ceramic coating air dried on the small parts. Heat drying adds a couple numbers of hardness. Use it for these properties, hard/durable finish, and very thin thickness. It is used also for its heat properties. Also, used as a corrosion protective coating in very harsh environments. The coating appearance shows the manufacturing marks, with little fill in. Will post a few more photos showing detail and description of process. Know safety precautions before using.
Les
aotte1 is offline   Reply With Quote
Old 04-14-2021, 09:05 PM   #78
aotte1
Cab support repair (2nd mount). GMC 1966 suburban K10, second cab support is different from Chevrolet Suburban’s which is fixed. These are designed like 3/4 ton trucks.
Last photo shows original, before powder coating that melted cushion.
The first photos show material, plan to use in replacing original rubber. In photos 1-3, the body mount is temporarily stuck together to keep from loosing.
Trivia Suburban Note: Unrelated to this thread “Back to Future” movie 1985, has suburban parked on side of street in final sceens.
Old 04-14-2021, 10:00 PM   #79
aotte1
Comparison of second cab mount on Chevrolet Suburban
Old 04-19-2021, 11:41 PM   #80
aotte1
Transfer Case Shift Linkage/Lever
Going back to document the 1966 GMC K10 suburban, transfer case shift linkage and lever, before back to fitting out the frame. Found these parts misplaced for awhile, along with rear e-brake cable for the Dana rear axle. Will post e-brake cable information next. Photos as removed, parts power washed next.
Note: Difference from 1964 Chevy K10 and 1966 GMC K10 Suburban, transfer case shift level hole in high hump. Two Chevrolet's ( 1964, 1965) have a round shift lever hole in hump, and GMC has an oblong hole, as shown by photos 4 and 5. Will post photos of actual high humps soon. Is it a year difference or chevy/GMC?
Old 04-19-2021, 11:55 PM   #81
aotte1
Transfer case linkage/shift lever power washed.
Old 04-19-2021, 11:59 PM   #82
aotte1
A few more power washed. Note, the rod end that connects to TC lever is not welded to rod straight. It has an angle offset. Photo four shows offset better. This offset is same on 1964 K10 truck shown also in photo 4 coated. The 1964 rod shows more angle in photo 4, because it is rotated more to show offset angle. Both appear to be same angle.
Old 04-20-2021, 12:28 AM   #83
aotte1
One last photo showing paint drips on rod, from dipping in paint? Will show whole rod with multiple drips and paint. Will get back to the more interesting photos of parts cleaned/coated/installed on frame soon.
Old 05-26-2021, 10:26 PM   #84
aotte1
Today received new aftermarket rear e-brake cables (66 GMC 4 WD suburban). Photos of cables below. The case is 46” contact point to contact point. Front end is 9” contact point to front end. The rear cable length needs to be set based on rear axle used.
Note: These cables are built for newer rear axles that use a barrel connection to backing plate.
Old 06-09-2021, 09:09 AM   #85
60-66
60-66's Avatar
Great job on the GMC Les . Wanted to mention if you are at all interested in original looking GMC Parking brake cables , I know a guy in PA that makes them. Great to deal with, look exactly like originals
https://67-72chevytrucks.com/vboard/...1966+gmc+panel
IS IT an EATON or Chevrolet rear axle https://67-72chevytrucks.com/vboard/...d.php?t=843778
The hubcap thread http://67-72chevytrucks.com/vboard/s...d.php?t=702839
WANTED : 1963-1966 6 Cylinder Fan Shroud
WANTED :1964-1966 PANEL TRUCK
60-66 is offline   Reply With Quote
Old 06-11-2021, 08:50 AM   #86
LT7A
Interesting thread. Thanks for your efforts to document specifics.
Old 06-20-2021, 01:40 AM   #87
aotte1
Great job on the GMC Les . Wanted to mention if you are at all interested in original looking GMC Parking brake cables , I know a guy in PA that makes them. Great to deal with, look exactly like originals.
Thanks Jon, yes interested in referral.
LT7A thanks for the support.
Not a lot of posting lately, been busy cleaning parts along with family activities. More posts to come soon.
Old 11-07-2022, 11:39 PM   #88
aotte1
A few photos of dash primed in PPG industrial epoxy high build. Dries nice and hard. Has a little orange peal.
Old 11-08-2022, 01:35 AM   #89
DPowers
One foot in front of the other
DPowers's Avatar
Looks good Les.
DPowers is offline   Reply With Quote
Old 01-27-2025, 03:32 PM   #90
Baketown Scotty
Junior Member
Baketown Scotty's Avatar
Wish I had found this earlier. Lot of good work there. Have my 1966 GMC Suburban 4x4 all apart and starting to put back together now. Any more progress?
1964 Chevy Suburban 4x4
Baketown Scotty is offline   Reply With Quote
Old 10-01-2025, 04:40 PM   #91
61K10
61K10's Avatar
Hay Les--Ben awhile sence we talked. I see you are having fun again. As usual doing a great job and i'am glad you have some help. I'am going to sell my61k10 as i don't drive it any more, hardly any miles on it. It's still like new. Keep up the good work as usual.
Hope you and family are doing well. Ok here, just getting old (76)
Take care Les will keep an eye on your project.
Kimble-----------------
1961 chevy K10
my build is------------61K10 build
61K10 is offline   Reply With Quote
Old 02-01-2026, 12:25 PM   #92
Wellwood
Junior Member
Wellwood's Avatar
A good read - thanks to the OP for sharing.
As previously posted - any further updates? Hope its on the road by now.
Wellwood is offline   Reply With Quote
