66 C10 Headlight Backing Plates
Hello,
Spaced, and did not take pics before disassembly. Now I have grille and backing plates painted and ready to put back together. I do not recall how the backing plate tabs go... 2 outer Def go under the grill tabs, but not sure about the other two. Anyone have one they can check? ...these originally were riveted. Thank you Manuel Server says too busy to attach pics. Last edited by Just1randall; 02-01-2026 at 12:02 AM. Reason: Adding pics |
![]() Join Date: Jun 2005
Re: 66 C10 Headlight Backing Plates
You would be better off posting in the 60-66 message board.
70 C/10 SWB 402/TH400/3.73 "The Needy Beast" 200,000 Mile Club Disc Brake Club Owner installed options: Front Sway Bar Power Steering Power Brakes Cigar Lighter Courtesy Lights Deluxe Side Markers Wiper Delay Sliding Rear Window Power Windows Power Locks Sniper EFI 2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear |
One foot in front of the other
![]() Join Date: Aug 2008
Hope this helps. Have put together a few.
Thank you dpowers, this is exactly what I needed. 🙏
Now I can get it buttoned up. ... those grilles look good too! |
#5 | |
Couple of pointers: Put the bezel clips that hold the headlight bezels in before attaching the brackets. mock up the adjusting screws first to the headlight buckets before installing the plastic inserts. Call me at 423 736 0421 if need any further assistance. |
Understood... ill def do that. Ty so much!
| Bookmarks |
