Is early transfer case replacement a sign of an overworked engine?
I'm about to look at this '02 Sierra with 141k miles for potential purchase and the guy is having to wait on its transfer case to be replaced before showing it. I've seen a lot of trucks advertised, but not too many mentioning T case work being done at this early mileage.
Does T case replacement at 141k miles indicate the truck's been overworked with pulling heavy trailer loads? What signs of overuse should I look for on this upcoming inspection, keeping this T case replacement in mind? https://imgur.com/a/9HFDHQv
'If the end of the world ever comes move to Kentucky, because everything there happens 20 years later.' ~ Mark Twain |
Re: Is early transfer case replacement a sign of an overworked engine?
A lot of those trucks have pump rub issues. I believe it is the transfer case oil pump rubbing on the magnesium case, causing issues and eventually transfer case failure. If I remember right high RPM in 4wd makes this issue worse. Is this truck AWD? I think those also had more issues?
I don't know that the transfer case would scare me away from the truck as long as it is priced accordingly. At the very least I don't know that the transfer case replacement makes me think that the engine has had a hard life.
1970 C/2500 Ol' Green https://67-72chevytrucks.com/vboard/...d.php?t=6680032016 GMC Sierra K1500 1953 Mercury 2 Door Sedan https://67-72chevytrucks.com/vboard/...17#post9381817 |
Moderator
![]() Join Date: Oct 2008
It's possible the oil pump rubbed through the tailhousing case half.
https://www.merchant-automotive.com/...transfer-case/ There are two possible repairs. Merchant Automotive makes a replacement for half of the pump housing. https://www.merchant-automotive.com/...mp-Upgrade-Kit Several outfits make a stamped steel plate to protect the alloy case half without disassembling the oil pump. You'll need a case half if it's perforated.
1959 M35A2 LDT465-1D SOLD 1967 Dodge W200 B383, NP420/NP201 SOLD 1969 Dodge Polara 500 B383, A833 SOLD 1972 Ford F250 FE390, NP435/NP205 SOLD 1976 Chevy K20, 6.5L, NV4500/NP208 SOLD 1986 M1008 CUCV SOLD 2000 GMC C2500, TD6.5L, NV4500 2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263 2009 Impala SS LS4 V8 RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...
And please let us know if and how your repairs were successful. Last edited by hatzie; 02-03-2026 at 08:11 PM. |
#4 | |
| Bookmarks |
