Old 02-10-2026, 01:27 PM   #1
Husker
Husker's Avatar
Rocker install
Do I need to use the piece in front of the rocker? The rocker does not touch the piece on the cab across the door way. The flat piece lays in behind rocker top to bottom. Thanks
Ron
Member #111
68 C-10 Daily Driver
70 4x4 Project
76 Jeep CJ-5
Help Support the Board:
http://67-72chevytrucks.com/vboard/payments.php
He who knows nothing is closer to the truth than he whose mind is filled with falsehoods and errors.
Thomas Jefferson
Husker is offline   Reply With Quote
Old 02-10-2026, 02:21 PM   #2
hewittca
hewittca's Avatar
Re: Rocker install
I believe that flat piece in front of the rocker is if you only need to replace a section of the inner rocker. Given that you have already replaced the entire inner rocker I don't think you need the other piece. I ended up doing the same thing on mine and realized I did not need that extra piece. The outer rocker should sit on the ledge of the inner rocker and you need to spot weld the two horizontal faces together. Here's a few photos of mine in process.
Builds: Green Gus the 68 C10 | Bluey the 72 1500 | Lowly the 70 C10 | Oscar the 70 C10
C10 Concept/Development Photos: Master Thread
hewittca is offline   Reply With Quote
Old 02-10-2026, 02:30 PM   #3
Husker
Husker's Avatar
Re: Rocker install
That's what I thought. Thank you
Ron
Member #111
70 4x4 Project
76 Jeep CJ-5
Thomas Jefferson
