Old 02-08-2026, 01:01 PM   #1
chappys4life
1 3/4 header for lowered truck
Working in a 383 swap in my 70 gmc. It had a set of think flowtek headers on it and looking for a new set as this 383 as I need something that can flow better. Right now it has a 2.5 drop spindle but I plan on bringing it a title lower as I plan on doing qa1 but nothing crazy low.
I am trying to find a 1 3/4 primary that will work. My knee jerk was a set of hooker super competition but the truck model I’m afraid is going to hang too far below the frame. I was looking at the ultimate header for a Camaro but is only 1 5/8 and I need 1 3/4.
Looking for any suggestions. I do have an automatic (right now it’s a th350 but have a 4l80 I plan on swapping to eventually) and a smaller pmrg smaller starter.
chappys4life is offline   Reply With Quote
Old 02-08-2026, 02:20 PM   #2
70STOVEBOLT
70STOVEBOLT's Avatar
Re: 1 3/4 header for lowered truck
Chevelle mid length headers in your favorite flavor. Might interfere with stock shift linkage, YMMV. I had to rework mine. Also, stock trans xmember will not work with these headers. The upside is they allow you to tuck the exhaust between the frame rails. There are several threads on here about tucking the exhaust, just use the search bar.
70 C/10 SWB 402/TH400/3.73 "The Needy Beast"
200,000 Mile Club
Disc Brake Club
Owner installed options:
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Sliding Rear Window
Power Windows
Power Locks
Sniper EFI
2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear
70STOVEBOLT is offline   Reply With Quote
Old 02-08-2026, 10:27 PM   #3
chappys4life
I was afraid of that. I ditched the factory shifter for a lokar. Also I ordered a tinworks transmission crossmember to help with routing.
Anyone running Dougs D369 or Hooker 2116? Looking for a solid set of headers.
Old 02-09-2026, 02:12 PM   #4
MikeB
MikeB's Avatar
Might want to look at Doug's Headers, which is a Pertronix company. I bought a pair for my 69 C10, and they sat quite high. In fact they terminated right in front of the trans crossmember, I didn't want to modify the crossmember or use tight bends, so ended up using a pair of stainless 3/4 length 1-5/8" Hedmans on my mild 350.
You could always use 3/4 length headers, which will work great for a street truck. But there are guys that know a lot more about that than me!
Mike
1969 Custom/10 LWB -- owned for 37 years. 350/TH350, 3.08 posi, recent AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. Hedman stainless headers. Old Air installation in progress.
1982 Custom Deluxe 10 SWB -- converted from 250-six to roller cam 350 w/ Vortec heads -- sold
1981 C10 Silverado LWB, 305, TH350C -- sold, but wish I still had it!
1969 C10 (not the current one) which I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming.
Retired as a factory automation products salesman.
Worked part-time over the years for an engine builder and a classic car repair shop.
Member here for 26 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then!
MikeB is offline   Reply With Quote
Old 02-09-2026, 03:04 PM   #5
chappys4life
I actually listed a dougs part number for a chevelle Dougs D369 or Hooker 2116. The kicker for our truck model is they are only 1 5/8, I need 1 3/4
Old 02-09-2026, 05:02 PM   #6
SCOTI
SCOTI's Avatar
Agreed.
3/4-length/mid-length sbc headers should be available in 1.75" diameter primary pipe size & offer the ground clearance lowered trucks need..... https://www.summitracing.com/parts/p...model/chevelle
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 02-09-2026, 05:08 PM   #7
chappys4life
Originally Posted by SCOTI View Post
Agreed.
Yeah I saw dougs D337 set I am real tempted. I am torn the Hooker 2116 are full length and only 250 more. Might risk the Hookers. I saw people using the Hookers on a big block c10 and fit well but cannot find any posts for a small block. I was going to call summit and see the return policy if i try them
Old 02-09-2026, 05:38 PM   #8
SCOTI
SCOTI's Avatar
For a street driven vehicle that has the power output requiring the need of 1.75" primaries, the 3/4-length units do what needs to be done. Sure, tuned, full-length headers are great, but I highly doubt you'd notice a difference during 'seat of-the pants' John Q. Public road analysis & you'll appreciate the added clearance 10 out of 10 times.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 02-10-2026, 11:41 AM   #9
chappys4life
You are probably right. With adding the supercharger I want to get my maximum horsepower. I almost bought the Hookers last night but found Dougs have a stainless model so swaying pretty hard to the D369-SS. I would get them cerakoted for heat more than likely but like I can dent one if needed and dont have to worry about the coating breaking and starting to rust.
I did attach a picture of the Hookers on a big block c10 and you can see they are pretty tucked. I would be on frame if hitting the headers
Old 02-10-2026, 11:54 AM   #10
MySons68C20
MySons68C20's Avatar
Following....great thread!
MySons68C20 is offline   Reply With Quote
Old 02-10-2026, 01:30 PM   #11
MikeB
MikeB's Avatar
Yes, Summit is pretty good about returns. I had no problem at all returning my Doug's headers. I think they will pay for return shipping only if they sent you the wrong part, if the part is not as described, or something else that's their fault.
However, I live only 40 miles from their Texas warehouse, so can just drive there. That also lets me check out their Outlet Center, where they sell returns and scratch & dent items.
Mike
Old 02-10-2026, 01:45 PM   #12
70STOVEBOLT
You might want to look at Sanderson also, a lot of guys sing their praises on the stainless 3/4 headers.
200,000 Mile Club
Disc Brake Club
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Sliding Rear Window
Power Windows
Power Locks
Sniper EFI
Old 02-10-2026, 02:15 PM   #13
chappys4life
Oh man that is awesome! I live in Austin so I get quick shipping but not that good.
Old 02-10-2026, 07:12 PM   #14
chappys4life
I ended up buying the D369-SS today. I was going to wait until I got the tinworks transmission crossmember in but saw I could do the 80 off on summit and just seemed like a solid deal. Will test fitment hopefully this weekend. Depends on how much of a nightmare the tinworks cross member swap is. Wish I had done it when I had the motoro and trans out.
Old 02-11-2026, 12:17 PM   #15
70STOVEBOLT
That pic looks just like mine. I don’t know if the small block headers would be any lower or higher.
200,000 Mile Club
Disc Brake Club
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Sliding Rear Window
Power Windows
Power Locks
Sniper EFI
Old 02-11-2026, 12:20 PM   #16
chappys4life
Good to know thank you. The Dougs D369-SS should be arriving today. I might pull the headers I have now and see if I can test fit them before I do the tinworks crossmember install just to see fitment. The tinworks arrives tomorrow so a busy weekend for sure.
Old 02-11-2026, 12:47 PM   #17
SCOTI
SCOTI's Avatar
Use Blue painters tape anywhere there might be possible contact issues to avoid scratches.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 03-03-2026, 11:03 AM   #18
chappys4life
Got the headers in and wow its tight. Had to bend my cooler lines, move a brake cable, and take out the starter but its in.
New issue is the headers sit lower than the tinworks crossmember. So I either have to cut the transmission crossmember or get a different one. Was going to get the same headers for my 79 suburban but think I will try the clippsters on it and might try and use the tinworks on it.
