![]() Join Date: Jan 2025
Firewall assembly markings
My truck was repainted with the goal of faithfully recreating its original factory finish. When I purchased it, these markings were present on the firewall. I later tracked down the owner who had the repaint done, and he explained that he photographed the truck beforehand and carefully reproduced the markings as they originally appeared.
At first, I wondered if they might have been approximated from another truck or recreated from memory. However, they correspond exactly with my truck’s engine, trim code, options, and SPID information. That confirmation makes them especially meaningful, as most of these original markings are typically lost or erased over time. It’s a small but authentic detail that helps preserve the truck’s original identity.
1972 C10 Custom Deluxe Highlander 402 Freedom isn't safe, it requires you to take responsibility for your own life, your own safety, and your own success. It carries with it the possibility of failure and the understanding that you're working without out a safety net. If you give the state the responsibility for any of these you also give up the freedom that accompanies the responsibility. |
Re: Firewall assembly markings
for what its worth, not all trucks had the markings...or at least to the new buyer. I worked at a Chevy dealership in the early 80's and as a car detailer, we were instructed to remove these in the prep stage right after delivery. I suspect Chevy had specific guidelines for dealerships to follow for preping new vehicles, and this was one line item to follow - but all didn't follow
My '72 C10 has all the factor paint on the firewall, and there are zero remnants of the "caulk marks" (Atlanta build)
'72 C10 Cheyenne SWB North Carolina kept for 50 years, 75k original miles, Medium/Hawaiian Blue paint, 3 owners - one for 40 years & garaged kept. Original: sheetmetal, undercarriage, moldings, glass, immaculate unrestored bed. * * * New - rebuilt engine at 65k in 2015, one frame-on respray in 2010, front bumper, blue houndstooth seat, carpet, 8 inch rally wheels on 275-60R-15, LED lighting. - Semper Paratus! |
#3 | |
I am pretty sure the "T2" markings on each side were the trim code and the Highlander level 2 package.
![]() Join Date: Feb 2002
I bought my '68 C/10 Stepside in 1973. Fremont truck. Obvious fleet buy unit. I don't remember if it had any firewall crayon graffiti, but if it had I would have rubbed it out over 50 years ago.
![]() ![]() Join Date: Sep 2008
The markings on the cowl was a St Louis Assembly plant thing.
Ram-A-Lam-A-Ding-Dong
![]() Join Date: Jan 2013
When I worked for Chevrolet dealers, we had our own marking system for stock number purposes. I never paid attention to whether there were factory markings, tbh.
![]() Join Date: Mar 2022
I’m no expert but I don’t think I’ve ever seen specific RPO codes in chalk like the ones recreated. Maybe someone will prove me wrong.
The only markings I’ve seen and are things like the model of the truck, the color code (in my case 507 light blue) then other cryptic stuff. This truck has 1116 then had 495 on the lower center firewall behind the engine….whatever those mean. |
![]() Join Date: Jul 2007
All I am gong to say is that years ago my wife and I went to a regional Mustang event and a lot of the participants with stock early Mustangs were wetting on their shoes because there was an old dude there who had been an inspector on the Mustang line and he would verify the marks on the firewalls. That told me right there why I would never make it as a restorer.
![]() Join Date: Oct 2013
For anyone interested, there are several threads on this forum that go into the weeds on factory markings. A simple search will get you to them. Procedures and markings varied from plant to plant. Larry is correct, St. Louis was the most prolific. Their firewalls usually denoted trim level (2T, 4T..probably short hand for Z62 and Z84), model number, engine RPO, trans RPO and whether or not they had power brakes. A/C was denoted under the heat exchanger box on so equipped models and most of them had the actual paint color written on the bare metal there. St Louis didn't stop with the firewall, the build sequence number (and model number) was written on the chassis. It was also on the core support and the back of the gauge cluster. Those are the big ones, but there was more.
Flint wrote on the firewall, but less info. Fremont actually wrote in the wet paint on the firewall. A lot of fun details in the individual assembly plant protocols.
1970 K20 Z62 https://67-72chevytrucks.com/vboard/...56#post9334756 1970 Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=645076 1969 K10 SWB CST http://67-72chevytrucks.com/vboard/s...52#post8520352 1971 K20 Z84 https://67-72chevytrucks.com/vboard/...90#post9047290 1946 B.F. Avery Model A Tractor http://67-72chevytrucks.com/vboard/s...55#post8292555 "Sometimes I wonder if zander208 was even real..." |
Mine is a St Louis truck so that explains why my firewall looks like railcar out of the eastside. It was cool for the previous owner to document and recreate them. If you have them then the numbers usually match the codes on the SPID in some manner or they are a shortcut of the SPID codes.
#11 | ||
Some grease pencil marking threads: http://67-72chevytrucks.com/vboard/s...light=sequence http://67-72chevytrucks.com/vboard/s...light=graffiti http://67-72chevytrucks.com/vboard/s...light=graffiti http://67-72chevytrucks.com/vboard/s...light=graffiti http://67-72chevytrucks.com/vboard/s...light=graffiti http://67-72chevytrucks.com/vboard/s...d.php?t=545345 http://67-72chevytrucks.com/vboard/s....php?p=6543084 Quote:
My own truck was "number 87". K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ Last edited by Keith Seymore; 02-18-2026 at 01:03 PM. |
#12 | |
![]() 46 years in Product Design/Development and vehicle assembly, across 12 GM assembly plants (including Flint, Janesville, St Louis, Oshawa, Pontiac). K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
Wow, tell us more and share if you would please. Is the story about a pop bottle in a frame true or trucks being built on Fridays.
Not a bottle, but a can, in a '64 Impala a friend of my dad's had. It had an occasional clank at the rear of the car. Not until it got hit and some metal moved was the Pepsi can found. I don't recall where it was, but it wasn't found until after the accident.
#16 |
And then, of course, my bio and build thread here:
https://67-72chevytrucks.com/vboard/...d.php?t=342926 As well as some stuff about growing up with Pontiacs: Pontiac Bio: https://forums.maxperformanceinc.com...d.php?t=560524 "Old Wives Tales": https://forums.maxperformanceinc.com...d.php?t=556607
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ Last edited by Keith Seymore; 02-18-2026 at 03:01 PM. |
#17 |
#18 | |
#19 | |
Mark 72 c20 custom camper Husky edition, 66 SS396 Chevelle 1964 Hawk, 63 Avanti,62 lark 1969 AMX , 1968 c20 stepside ,85 K20 1977 Suburban sold 68 anniversary. |
#20 | |
It was single stage, and there was no after treatment (except for whatever flow you got from the bake ovens). Probably better described as thin in some spots and heavy/runny in others. It progressively got better, especially when you moved into the base coat/clear coat era (starting 1989 model year for trucks). K
#21 | |
If you wanted a black car they would build it in primer and you'd have to get it painted after you got it. K
#22 |
My Chevelle (1974, built in Oshawa) did not get any paint inside the trunk under the rear package tray. It is still bare even today.
It had been crashed in the assembly plant. The first time we pulled the fenders off to paint them there was bondo around the wheel opening on one side. My GTO (1965, built in Pontiac) has the worst original paint I have ever seen on any vintage vehicle. There are hairs in the paint, handprints in the wet paint in the hood, and a big swiped area on the trunk lid that looks like some one wiped some solvent over it. Those are all still there to this day. K
#23 |
For show vehicles we used to "flatten" the paint: the guy would take a tongue depressor wrapped with some 600 grit sandpaper and knock all the high points down, and then wheel it out. That happened at the Milford Proving Ground paint shop, or at the Design Studio, long after the vehicle left the assembly plant.
When I had to fluff and puff vehicles for upper management I had a list in my head of all the things I knew I would have to do, even before I got it: * fix wind noise * balance and vector tire/wheel assemblies * zero balance driveline * fix the paint * fix all squeaks and rattles * etc K
| Bookmarks |
