Old 02-16-2026, 04:14 PM   #1
Luke87gt
Luke87gt's Avatar
1969 front headlights
Hi all, I’m trying to adjust the headlights on my 69.
I see the X-axis and y-axis adjustment screws but that doesn’t seem to be the issue.
The issue is that the headlights are totally off center from the bezels/grill, probably 1/4” (the headlights would need to move outward in order to center the headlight in the bezel.
Appreciate any input on this, thank you!
1969 C10 Shortbed
Luke87gt is offline   Reply With Quote
Old 02-16-2026, 09:55 PM   #2
70STOVEBOLT
70STOVEBOLT's Avatar
Re: 1969 front headlights
Please post pics so we can better help you.
70 C/10 SWB 402/TH400/3.73 "The Needy Beast"
200,000 Mile Club
Disc Brake Club
Owner installed options:
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Sliding Rear Window
Power Windows
Power Locks
Sniper EFI
2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear
70STOVEBOLT is offline   Reply With Quote
Old 02-17-2026, 11:47 PM   #3
dmjlambert
dmjlambert's Avatar
The truck was not engineered to have tolerances within 1/4 inch. Anywhere on the truck.
Old 02-17-2026, 11:52 PM   #4
RustyPile
RustyPile's Avatar
Tolerance in some areas -- within the same building....
RustyPile is offline   Reply With Quote
Old 02-18-2026, 04:35 PM   #5
Luke87gt
Luke87gt's Avatar
Sure thing
Appears the headlamp needs to move outward by about 1/8 - 1/4”. Same on the other side.
1969 C10 Shortbed
Old 02-18-2026, 05:12 PM   #6
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Yeah, that doesn't look right. Makes me think there's an issue with the mounting of the headlight buckets.
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Old 02-18-2026, 06:41 PM   #7
nightmare
nightmare's Avatar
Are you sure that the black bezels are on the correct sides?
Mike
2001 Dakota R/T - Silver CC - 1 of 1671 •360 w/46RE •392 limited slip
1972 Chevy Suburban - Turquoise/Black
1969 Chevy C/10 - Blue LWB •350 w/ 700R4 •3.73 posi •PS PB A/C - SOLD
Using your turn signal is not "giving information to the enemy"
67-72 FAQ
Originally Posted by GMCMAX View Post
My lugnuts require more torque than your honda makes!
nightmare is offline   Reply With Quote
Old 02-18-2026, 08:19 PM   #8
Luke87gt
Luke87gt's Avatar
No not sure, that’s how the truck came.
I guess I can swap and see.
Interesting that his is happening on both sides (headlight needs to move outward in both cases)
1969 C10 Shortbed
Old 02-18-2026, 08:22 PM   #9
Steeveedee
Ram-A-Lam-A-Ding-Dong
Steeveedee's Avatar
You should be able to see both adjustment screws past the cutouts on the bezels. If so, they are on the correct side(s).
~Steven
Simi Valley, CA
Old 02-18-2026, 08:52 PM   #10
Luke87gt
Luke87gt's Avatar
The lower/inner adjustment screw is right on center. The upper/outer adjustment screw is offset by 1/8” (which would make sense since the headlamp doesn’t appear centered to the bezel)
I guess it wouldn’t hurt to just swap the two bezels to rule out the previous owner putting them on the wrong side.
Do the headlight buckets have any adjustment at all?
1969 C10 Shortbed
Old 02-18-2026, 08:58 PM   #11
Rust_never_sleeps
Rust_never_sleeps's Avatar
Y adjuster is above the headlight, X screw is towards the centerline of the truck(also towards my finger if that helps ;-) )
1970 C10 Custom longbed 350/350
“Carburetors are forgiving, timing is not” — Thunderhead289
Rust_never_sleeps is offline   Reply With Quote
Old 02-18-2026, 09:15 PM   #12
Rust_never_sleeps
Somehow the shadows on black on a grey day didn't make the most compelling image
This is driver's side
Old 02-18-2026, 09:16 PM   #13
Luke87gt
Luke87gt's Avatar
Interesting!
Do you see at the bottom of yours, there’s a rounded side. My rounded side is on the right. That leads me to believe they very well could be swapped accidentally. Will check
1969 C10 Shortbed
Old 02-18-2026, 09:22 PM   #14
Rust_never_sleeps
Originally Posted by Luke87gt View Post
Interesting!
Do you see at the bottom of yours, there’s a rounded side. My rounded sound is on the right. That leads me to believe they very well cold be swapped accidentally. Will check
I can't see enough to tell, but if they're swapped, they're also rotated 90*, so what you're saying is plausible....assuming the pic is your driver's side light
Just another adventure in forensic restoration ;-)
Old 02-18-2026, 10:06 PM   #15
Luke87gt
Luke87gt's Avatar
My pic is the driver side
So my expectation is that they need to be swapped and rotated 90deg
Will report back soon.
Edit: turns out the two sides were swapped by previous owner. I swapped them this evening and the gap improved.
The joys of discovering things on your 56yr old pickup lol
Thanks for the help guys!
1969 C10 Shortbed
Old 02-18-2026, 11:50 PM   #16
nightmare
nightmare's Avatar
I'm glad it was a simple fix.
Mike
67-72 FAQ
Old 02-19-2026, 01:26 AM   #17
Luke87gt
Luke87gt's Avatar
Likewise!
That’s a clue for others. If your headlights seems to be too far inward on both sides, check that the bezels are not swapped from side to side. Good luck all!
1969 C10 Shortbed
Old 02-21-2026, 04:55 PM   #18
Luke87gt
Luke87gt's Avatar
By the way, wondering if you guys have any recommendations for some bright aftermarket headlights that still look close to oem.
The amount of light these stockers give out is flat out dangerous lol
1969 C10 Shortbed
Old 02-21-2026, 05:36 PM   #19
Rust_never_sleeps
First, put in a relay kit first. Your existing bulbs will be much more effective with a full 12V
I went ahead and put in basic parts-store halogens(Sylvania SilverStar IIRC) Whiter and brighter, but still look authentic(see above pic ;-) )
Old 02-21-2026, 05:39 PM   #20
Steeveedee
Steeveedee's Avatar
Here's an A/B comparison for what the relays will do. Yes, the lights are on in the first pic.
https://67-72chevytrucks.com/vboard/...d.php?t=782071
~Steven
Simi Valley, CA
Old 02-21-2026, 06:09 PM   #21
dmjlambert
dmjlambert's Avatar
Headlights do get dim after some decades. I like Sylvania or Wagner H6024 Basic sealed beam halogen headlights. Walmart was stocking them but looks like they are out of stock right now. Typical price is $12 to $16 each or car parts store $20+. The fancy ones like SilverStar or XTRAVision are slightly brighter but burn out much more often.
https://www.walmart.com/ip/Sylvania-...-Pack/16913604
https://www.amazon.com/dp/B0006H8QIU?th=1
https://www.oreillyauto.com/detail/c...f-1/syl0/h6024
Old 02-21-2026, 06:27 PM   #22
A1971Blazer
A1971Blazer's Avatar
I'm using the same ones on my '67 with the relays wired under the hood for the headlights.
At full charging voltage, they're getting 13.5-14.5 volts straight from the alternator output.
I made a load center for the LS swap so I just put the headlight relays right into it.
I used a breaker rather than fuses for the headlights.
The terminal block is for all the LS wiring.
I have to remove the bezels to adjust them.
1967 C10 Step side
1968 C10 Step side
1970 Chevrolet K/5 Blazer
A1971Blazer is offline   Reply With Quote
Old 02-21-2026, 10:18 PM   #23
Rust_never_sleeps
I too installed self-resetting breakers. One for high beam, one for low
Old 02-25-2026, 11:54 AM   #24
mkmc69
mkmc69's Avatar
Attachment 2442763
Attachment 2442764
Very nicely done! Where did you mount your panel? Hard to tell from the picture.
mkmc69 is offline   Reply With Quote
Old 02-25-2026, 12:18 PM   #25
A1971Blazer
It's on the driver side, back side of the core support. PCM is underneath it.
It has a cover that latches on, there's room for 2 spare relays and a little bag of extra fuses
Name:  IMG_1401 (1)_inPixio.jpg
1967 C10 Step side
1968 C10 Step side
