Re: 65 C10 Brakes Question
That's a very simple 1 circuit system so you would need to identify where the restriction is.
The rear brake line is smaller than the front so flow will be slightly lower but still should be good. If both rear cylinders are the same I would start by disconnecting the flex line at the rear axle and see if you get decent flow there. then move forward to the T junction at the right front wheel. |
| Bookmarks |
