Old 02-26-2026, 01:49 PM   #1
chappys4life
Radiator Holder
On my 79 suburban it currently has a 4 core radiator but is leaking so I ordered a new Campion American Eagle 2 core AE716 but now the the radiator is thinner and shorter than the original so the original radiator support bracket does not work. Looking for any options. Right now I stole my 70 c10 holders but as you can see do not fit ideally.
Doers not have to be a factory look but something that looks solid.
Was wondering if #3 on this diagram would work?
https://www.lmctruck.com/mechanical/...tor-components
chappys4life is offline   Reply With Quote
Old 02-27-2026, 12:06 PM   #2
chris989
Re: Radiator Holder
you could try the SBC version? But i think your problem the the rubber as much as the radiator. there is a lot of slop due to the different design.
Is the radiator returnable?
chris989 is offline   Reply With Quote
Old 02-27-2026, 01:48 PM   #3
chappys4life
Re: Radiator Holder
It is a sbc truck, looking at the light service manual I have the one on the left. I was debating the other two or i just need to make a bracket. I looked at champion and all of the radiators for a c10 are the same external dimensions so I would run into the same issue.
