Old 03-04-2026, 06:31 PM   #1
PapaJbbq
Vortec Upper Rad Hose?
I've put a Vortec from a 97-99 C1500 in my 66 with an aftermarket radiator.
I kept the serpentine drive, which (WHY??) has the AC on the left and alt on the right.
I need an upper radiator hose that will clear the AC and belt. The original had a water neck pointing to the drivers side, and a long, long hose behind the AC. I put on an adjustable neck, but the OE hose won't do.
Anyone solve this problem?
PapaJbbq is offline   Reply With Quote
Old 03-05-2026, 10:01 AM   #2
1964FarmFreshC10
Re: Vortec Upper Rad Hose?
This should probably be in the LSx Swaps section.
1964FarmFreshC10 is offline   Reply With Quote
Old 03-05-2026, 10:20 AM   #3
theastronaut
theastronaut's Avatar
I bend a wire to the shape I need and go to the parts store and ask if I can go in the back and check out the rad hoses to see if one matches up. Take a tape measure or ruler to check the ID.
Another option is to have a muffler shop bend a steel tube to match the shape you need and use short sections of hose at each end, like the factory did on 283 and 327 trucks.
Vortec 5.7 is a gen 1 sbc.
theastronaut is offline   Reply With Quote
Old 03-09-2026, 03:34 PM   #4
PapaJbbq
Thanks.
When you go to buy parts, it's a Gen 1.78192.
