Leif springs with coil overs
Hello folks. Sorry so long. Here is some background. I'm building a 53 Chevy 1/2 ton pickup Drag and Drive for the crowded 8.50 second class in the quarter mile. Drive train. 6-71 blown/nitrous Chevy inline 6 292, 1300ish reliable HP in race mode and 500ish HP in street mode on pump gas. Tremec T56 Magnum 6 speed. Factory custom built Frankland Quick Change (thanks Fred) with a Bicknell Torque Arm and a triple biscuit. I'm starting my chassis soon and need to make some decisions. I'm married to my Leif springs because it's a 53 pickup. I've owned and driven the truck since 1980. My front axle is a 4" drop custom one off made by Pete and Jakes with Superbell. Designed to leave the ground and safely return to earth. On the front I will be running Leif springs and a pan hard bar with double adjustable shocks and possibly coil overs for adjustability (why not?). If you are still with me my biggest concern is the rear suspension. In the rear I want Leif springs and double adjustable coil overs and a pan hard bar or Watts Link. When I'm in the drive mode that is usually about 1000 miles per event I will be hauling a single axel trailer !500ish pounds and Racing tires and wheels in the back. I need to be able to jack up the back to compensate for the extra weight. I would also like to be able to adjust the ride height. Not interested in air shocks. When I talk to the custom Leif spring people they want the weight on the axles right down to paint. If you are off you are just stuck with it. I don't want my Leif springs to be the last thing I buy. Why can't I just buy a lighter Leif spring and make up the difference with a coil over? I know this has been done. My problem is the Leif spring guys and the coil over guys don't seem to hang out together. I would like to use one vendor for the entire package instead of me trying to get it right. Is this a dumb idea? Do you know anyone that you can recommend to help me with it? I realize this is a big expense but I still have my left nut. It would also look pretty cool and chicks like the shiny stuff. Thank you for your time and any thoughts you have.
#2 | |
Re: Leif springs with coil overs
![]() Sorry, can't help, but I'll be watching because I was wondering the same thing about leafs and coilovers. |
I might have mentioned a blower. My 292 a work in progress, Billet crank, billet solid roller cam and steel billet rods all by Crower. Billet mains dowelled and girdled. 5 stage dry sump. Ryan Falconer V-12 head, semi-hemi chamber design (340I/220E). Weiand classic case 6-71 with 2 Quick Fuel 650 DP supercharger carbs and a 16 jet Holley nitrous fogger plate. Electromotive direct fire EMS.
I have done this on a few different vehicles.
VW bugs especially in the front for a progressive spring rate. The springs were for lack of a better term loose. So normal suspension movements I did not get to much into the spring. It really helped since it was slammed, and a full tank of gas made it bottom out easily. I have also done this twice on old mono leaf Novas. I kept the spring tighter for a lack of a better term to give me the firmness I wanted. So my preference from when I experimented with it is to set height with the normal spring. Then use the coil over to dial in spring weight in a progressive manner. You will need to buy a few different pairs to dial in your desires. |
#5 | |
I am following because = Blower.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller 72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350 |
#7 | |
I think I used 100# on the Novas. Now I use air bags for the same effect |
#8 | |
#9 | |
QA1 has a name and they want to protect it. If they recommend it and you have to tune with a few sets of springs. They sound like they lied to you. When you post up online complaints Besure to reinforce the shock mounts to handle the new weight being added to them . Look into rolling sleeve bags as a another option |
#10 | |
Have you talked with Calvert Racing? They are a drag racing oriented suspension company. With the popularity of the drag and drive events you're not the first one looking to do this.
The main problem I see with coil overs is you will likely need to remove them before making a pass down the strip to prevent binding of the rest of the rear suspension which would lead to poor traction and possibly problems keeping the truck in a straight line. My buddy had this guy help him with his Firebird suspension. https://youtu.be/WcA5xQGWpuY?si=VvUShs37xMqaHFYI Good luck! That's a cool project you've got there.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. ![]() RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
#12 | |
| Bookmarks |
