Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > Welcome and Discussion > General Discussion
Old 03-10-2026, 09:57 AM   #1
IT Cowboy
IT Cowboy's Avatar
How many miles on your stock motor without major work?
How many miles are on your stock motor(s) without any major work being done.
My truck has 60k on its 402 and one of the crank bearings was turned and shimmed about 15 years ago per the previous owner. Although yes that is pretty much major work I guess.
1972 C10 Custom Deluxe Highlander 402
Freedom isn't safe, it requires you to take responsibility for your own life, your own safety, and your own success. It carries with it the possibility of failure and the understanding that you're working without out a safety net. If you give the state the responsibility for any of these you also give up the freedom that accompanies the responsibility.
IT Cowboy is offline   Reply With Quote
Old 03-10-2026, 11:28 AM   #2
Steeveedee
Ram-A-Lam-A-Ding-Dong
Steeveedee's Avatar
Re: How many miles on your stock motor without major work?
The engine in my truck was rebuilt back in the early '80s. It probably got a timing chain at some point, as I vaguely recall my FiL saying something about it. After we inherited it, I checked for slack, but it's fine. Been about 100k miles since then. It's at about 218k now, and holds ~25 PSI at hot idle. Doesn't knock or smoke, and uses a quart of oil in about 1500 miles.
~Steven
Simi Valley, CA
Old 03-10-2026, 01:06 PM   #3
Shifty One
Shifty One's Avatar
254k on my 98 C2500 454, never been opened.
1987 V20 farm-hand rescue
1998 C2500 lot-rot rescue
Old 03-10-2026, 04:51 PM   #4
With my friend who had my 70 since 1978, the 3 prior engine all had around 160Kon them when he replaced them. Originally a 307, then 327, then 350. The current, 4th motor,, is a Jasper 350. Truck is about to turn over 500k.
Old 03-11-2026, 01:42 PM   #5
theastronaut
theastronaut's Avatar
Dad's '97 S10 has around 355k on the unopened original engine and trans. he bought it in '99 or early 2000 with only 7k on it. He's had to do an intake gasket (dexcool problems) and something with the timing chain messed up a couple years ago (don't remember the exact details) so it got a new chain, cover, and crank position sensor. It's had one AC compressor replaced with an OEM/AC Delco compressor, one tune up at around 200k (plugs/wires/cap/etc), one clutch at around 240k, and that's about it for the engine/drivetrain.
My '66 C10 had a reman longblock 250 swapped in at 136k in 1990 for $1,014 which included rebuilding the cylinder head, tune up parts, clutch, thermostat, belts, hoses, vacuum advance, carb rebuild, and air filter. It's still going strong at 172k.
theastronaut is offline   Reply With Quote
Old 03-11-2026, 02:53 PM   #6
57taskforce
All about them K’s
57taskforce's Avatar
Nice! Similar story here. 225K on my 98 K2500… 454, 4l80e, and the rest of the drive train is all original and still running perfect.
Tyler
57taskforce is online now   Reply With Quote
Old 03-11-2026, 04:10 PM   #7
MJN
MJN's Avatar
My '08 Envoy is just under 253,000 on the original, untouched 5.3L and 4L60E, and yes the AFM still works too.
'51 South Bend Model "9A"
'56 Chevy 3600 NAPCO
'08 GMC Envoy Denali
'12 GMC Sierra 2500HD Denali
'17 GMC Yukon XL
VCCA member #58596
http://www.nohrco.com
Old 03-11-2026, 07:31 PM   #8
Shifty One
Shifty One's Avatar
I had to rebuild the 4l80e due to the brick in the catalytic converter breaking free and plugging the exhaust causing a major heat-up next to the trans (at about 200k).
Old 03-12-2026, 12:23 PM   #9
MS66
MS66's Avatar
I believe he's referring to your old iron that grew up on the farm, traveling gravel roads, not the new stuff.
That said, my '68 C10 LWB fleet side grew up on the farm, has 61k on it and is still mostly original, besides the brushed on paint from 30 years ago. The original 250 still runs like the day it was bought, still has the original clutch and pressure plate in it. Truck came with 3 items on the SPID, one is an oil bath breather that, IMHO, is the best thing ever invented for farm trucks, contributing to the longevity of these old workhorses that were well maintained. It won't win any high mileage contests only sees about 1k a year now.
MS66 is offline   Reply With Quote
Old 03-13-2026, 05:45 PM   #10
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
My 402 failed and was rebuilt at 99K miles in 1993. 40K miles later it feels as good as ever. I've only installed a new chain, oil pump & shaft that came with a frame off.
Tony 1971 C10 Custom Deluxe SWB 402/400TH A/C
I developed an assembly information kit for restoring my truck from nuts and bolts. It's written in Assy. order, short & simple, packed with all OEM hardware ID; castings; part ID; 100s of part numbers; wiring simple - Resource, and trivial too.
Much info. applies to all 67-72 GM, A/C vehicles, esp. trucks W/O saying. Full search ability, including to 700+ images of illus., parts, charts, Assy., points of interest, cab, bed, & front clip cart plans- Specials and cores were serviced out and R excluded e.g. front/rear glass, body/paint, engine core, rebuilt hinges, steering box, trans, etc.
The project was in-line with long former professions developing process, policy, specs, demo, written for novices, admin., policy, engineers, development, systems & test - Public & govt 2, gross. Sell soft copy cheaply, PM if interested.
Build thread:https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline   Reply With Quote
Old 03-14-2026, 07:14 PM   #11
57taskforce
All about them K’s
Ehhh… well I see what your saying but we are talking about 30 year old GMT 400 trucks…
Tyler
