Old 03-11-2026, 10:32 PM   #1
Arnulfo
Exhaust manifold gasket
Seeking opinions on pros and cons of whether or not to use them. From what i understand the factory did not use them. Will be installing a new driver side manifold and head surfaces still in great shape. Thanks for the info
Arnulfo is offline   Reply With Quote
Old 03-11-2026, 11:52 PM   #2
Steeveedee
Ram-A-Lam-A-Ding-Dong
Steeveedee's Avatar
Re: Exhaust manifold gasket
If they have a lot of pitting, don't bother. I've used a product in the past (VersaChem Exhaust System Joint & Crack Sealer) on a set of exhaust manifolds. Worked a treat.
~Steven
Simi Valley, CA
Old 03-12-2026, 02:47 AM   #3
Arnulfo
No pits on the heads nor would i expect any pits on the new manifold. Thinking i may put a thin skin of high temp rtv with no gasket
Old 03-14-2026, 04:42 PM   #4
425HP409
425hp409
425HP409's Avatar
The factory did not use gaskets and the head and manifold surfaces were flat.
A gasket can have problems such as blowing out. they are to make up for not flat surfaces. I have built many engines and never use a gasket. I make sure the head is flat by running a bastard file over the manifold surface and also running the file on the manifold while it is in a vise until you can see the factory broach marks so you know it it flat. It will have high and low spots, make sure that you use the file until it is not leaving any part of the manifold not filled flat.
Charles
68 SWB, Dad bought new, now 396 & factory ac
64 Impala SS, 409 425HP, 4 speed AC
64 Bel Air Wagon, 400 Small Block
57 Bel Air all original 283 w/Factory Air
77 GMC Sprint, 454/425HP
67 Oldsmobile 442, all original
425HP409 is offline   Reply With Quote
