Old 03-16-2026, 12:30 PM   #1
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
Anyone have 15x7 front and 15x8 rear Rally Wheels on?
I have 15x8 but hear they wont fit the front due my 10c's 2.5" front spindle drop. Without modifications anyway, which I'm not doing. I collected some parts along the way and would like the Rally option.
A nice matching set of 15x7 are hard to come by, but two more easily achievable, so I wonder how it would look??
At the moment the truck sits level, not sure if I'd want to get tires to maintain that or perhaps a little lift in back, hmm.
Tony 1971 C10 Custom Deluxe SWB 402/400TH A/C
I developed an assembly information kit for restoring my truck from nuts and bolts. It's written in Assy. order, short & simple, packed with all OEM hardware ID; castings; part ID; 100s of part numbers; wiring simple - Resource, and trivial too.
Much info. applies to all 67-72 GM, A/C vehicles, esp. trucks W/O saying. Full search ability, including to 700+ images of illus., parts, charts, Assy., points of interest, cab, bed, & front clip cart plans- Specials and cores were serviced out and R excluded e.g. front/rear glass, body/paint, engine core, rebuilt hinges, steering box, trans, etc.
The project was in-line with long former professions developing process, policy, specs, demo, written for novices, admin., policy, engineers, development, systems & test - Public & govt 2, gross. Sell soft copy cheaply, PM if interested.
Build thread:https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline   Reply With Quote
Old 03-16-2026, 01:06 PM   #2
EagleChief
EagleChief's Avatar
Re: Anyone have 15x7 front and 15x8 rear Rally Wheels on?
I have a set of Corvette rally's (unsure what brand they are) on my truck that are 15x7 front and 15x8 on the rear. I'm using Cooper tires 235/70-15 on the front and 255/60-15 on the rear. I also have drop spindles - lowered 3.5" in front and 5" in back.
1971 C10 - Hugger Orange/White
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=780197
LS Swap Thread: https://67-72chevytrucks.com/vboard/...d.php?t=811460
EagleChief is offline   Reply With Quote
Old 03-16-2026, 01:08 PM   #3
3drburb
15x7 with 255/60. 15x8 with 275/60.
It's not the best picture with the front tire in a dip in the driveway.
3drburb is offline   Reply With Quote
Old 03-16-2026, 05:25 PM   #4
cericd
cericd's Avatar
Member/Moderator leddzepp built a truck that looked a lot like yours and ran staggered 15x7 and 15x8 truck rallies on it. His build thread used to be on here but I can't seem to locate it.
Here's a couple pic of his truck I found on the forum. He was running a 5 and 7 drop. Not sure if he had to modify his A-arms or anything to make it work though. Maybe he'll chime in.
Chris
My 1970 SWB C/10 - https://67-72chevytrucks.com/vboard/...d.php?t=534872
cericd is offline   Reply With Quote
Old 03-16-2026, 06:49 PM   #5
basketcase
basketcase's Avatar
I don't have the rear axles changed yet but these are 15x7 Corvette style rallys from Speedway Motors with 235/60/15 tires. I have 2" ECE front springs and 2.5" dropped spindles. I went with the 7" wheels on front because I thought the 8" stuck out too far. Just my preference. The rear is getting 8" 255/60.
'69 swb stepside in progress.
'59 Corvette lifetime project
basketcase is offline   Reply With Quote
Old 03-16-2026, 11:51 PM   #6
CAMAROBOY68SS
CAMAROBOY68SS's Avatar
I have wheel vintique 8 inch Corvette style rally's on all 4 corners of my truck. Im still 6 lug but no fitment issues with my dropped spindles.
The Twins:
1968 C10 SWB - Blue 327/5 Speed
1968 Camaro SS/RS - Blue 327/4speed
C10 Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=833278
The "Others"
1933 Ford Pickup (Camaro in disguise)
2017 Camaro SS
Life long Chevy guy
CAMAROBOY68SS is offline   Reply With Quote
Old 03-17-2026, 12:40 AM   #7
Luke87gt
Luke87gt's Avatar
Wait, what sort of issues are you guys seeing with 15x8 on the front?
1969 C10 Shortbed
Luke87gt is offline   Reply With Quote
Old 03-17-2026, 08:40 AM   #8
71CHEVYSHORTBED402
Exactly I've heard the lower control arms are too close, possibly a ball joint issue too? I've also heard 8" wheels work with drops; how can both be true? Probably rhetorical.
Thank you for images above. Nice trucks, and wow your set-up looks SHARP EagleChief, You had to have been "pleasantly surprised" when those were installed.
FWW some images of my clearance, 2.5" drop with 6" OEM wheels - 235-75-15 tires are a little fatter than original.
Old 03-17-2026, 09:19 AM   #9
HO455
HO455's Avatar
I'd bet that the folks have had issues with the rim or the balancing weights hitting the tie rod. I've run into that on S10's and my GTO with dropped spindles and 15 inch rally wheels.
A different backspacing of the wheel or a 1/4 -3/8" spacer will usually solve the interference problem.
RIP Bob Parks.
Old 03-18-2026, 12:01 AM   #10
Luke87gt
Luke87gt's Avatar
I’m basically building around a 15x8 front rally like thousands before me.
Hell, lots of people running 15x10 fronts even.
1969 C10 Shortbed
Old 03-18-2026, 01:50 AM   #11
3drburb
Your truck looks great btw.
Also you may be surprised how heavy the rally wheels are, I was, but I like the look.
Old 03-18-2026, 01:52 AM   #12
Luke87gt
Luke87gt's Avatar
Like four anvils. I was also taken back the first time I picked one up.
1969 C10 Shortbed
Old 03-18-2026, 09:42 AM   #13
SCOTI
SCOTI's Avatar
I keep seeing this one & the reply's with no mentions of WHY some people have issues with a certain wheel size while others don't. Nine times out of ten the interference issue is caused by the back-spacing of the particular wheel.
Width & backspace need to be stated in discussions about wheel/tire fitment. This will help others better understand why some combo's work where others had issues.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 03-18-2026, 10:19 PM   #14
Rich69shortfleet
I have 15x8 with 275/60-15 tires all around. No fitment problems. I have lowering springs. I converted to 5-lugs when I lowered it.
Rich69shortfleet is offline   Reply With Quote
Old 03-18-2026, 11:13 PM   #15
EagleChief
EagleChief's Avatar
Thanks! I appreciate it! When I bought the truck it had some wheels from an early 2000's truck on it. I don't even remember the size, now. I bought the rally's off of my old boss for $100, then had our shop sand blast and paint them. Once they were mounted on the truck, it completely changed the way it looked. Then once the new suspension went on and the height was lowered, I knew that was where it was supposed to be.
Old 03-19-2026, 03:12 AM   #16
71CHEVYSHORTBED402
Good point.....This should clear some things up. Incidentally, does anyone know the back space on an OEM 6x15 steel wheel?
____________________________________________________________________________________________________ ______________________
Check out this guy’s spindle drop with 8x15 Rallys. I nearly made the same mistake, almost pulled the trigger on having my 8x15 refinished. Geezuz, by the time I bought tires too only to find.... https://67-72chevytrucks.com/vboard/...d.php?t=677631
Same thread says the backspace on a 7x15 rally wheel is 3.5/8
This thread says the 8/15 rally wheel has a 4” back space.
https://67-72chevytrucks.com/vboard/...d.php?t=363898
Write-up on Rally Wheels. https://67-72chevytrucks.com/vboard/...d.php?t=462895
Says 4.25” backspace on a 8x15 Rally Wheel. He speaks of a lip, not sure what that means. I measured mine which was slightly less/more, maybe I’ll see if I can find the thread or measure again (Edit is last paragraph). I'm 80/20 sure you’re supposed to measure from below what he may be calling a lip, but I suspect he means outer aesthetics.
Like another source he says the back space on a 7x15 Rally Wheel is 3.5/8.
EDIT: I found some of my notes. I measure dead nuts 4.3/8 (4.375) backspace on my 8x15 rally wheels. So you got three choices, one guy says 4", another 4.25" and mine 4.3/8" I suppose it's possible some variances in Rally Wheels. Something tells me no......... An image for back space.
Old 03-19-2026, 10:10 AM   #17
SCOTI
SCOTI's Avatar
Check out this guy’s spindle drop with 8x15 Rallys. I nearly made the same mistake, almost pulled the trigger on having my 8/15 refinished. Geezuz, by the time I bought tires too only to find...... https://67-72chevytrucks.com/vboard/...d.php?t=677631
Says 4.25” backspace on a 8x15 Rally Wheel. He speaks of a lip, not sure what that means. I measured mine which was slightly less/more, maybe I’ll see if I can find the thread or measure again. I believe you’re technically supposed to measure from below what he might be calling a lip, which I did.
Like another source he says the back space on a 7x15 Rally Wheel is 3.5/8. In a nutshell the 8x15 Rally has .60ish more back space than the 7x15.
EDIT: I found some of my notes. I measure dead nuts 4.3/8 (4.375) backspace on my 8x15 rally wheels. So you got three choices, one guy says 4", another 4.25" and mine 4.3/8 I suppose it's possible some variances in Rally Wheels. Here's how I measured mine, which I'm mostly sure is the correct way. Sorry, it's hard to see, but I measured below that "ring" for lack of better term. In other words. it's measured from the flat surface because that's what contacts the hub's flat surface. The other guy's example is from the ring, which inserts into the hub.
I don't recall there being an area on the hub or rotor surface that is recessed for the 'ring' (?).
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 03-19-2026, 11:00 AM   #18
71CHEVYSHORTBED402
[QUOTE=SCOTI;9426962]I don't recall there being an area on the hub or rotor surface that is recessed for the 'ring' (?).[/QUOTE
Beyond the hub might be better term.
