Old 03-22-2026, 12:50 PM   #7
twoskies
twoskies's Avatar
Re: OER doors
I had outer Skins and inner bottoms done to mine from a friend, he did not have the truck at his house, he did make templates
When i started fitting them, i had to cut the drivers door on the bottom to bring it in quite a bit, welded up and cannot hardly tell
passenger door fit better, still had to work the hinges
also the rockers that you buy unless OEM are not straight, they bow, so i had to split both sides and adjust them
aftermarket metal almost always needs some massaging
Good Luck on your build
A Little Better Every Day
Cancer Survivor, most dont know what they have until its gone, appreciate everything
twoskies is offline   Reply With Quote
body work, doors, oer door shells
