Old 03-20-2026, 06:45 PM   #1
HeavyHauler
What sealant do you use on the TH400 with pan gasket?
I am getting ready to reinstall the trransmission pan on my TH400 in my 1968 Chevy C10 shortbed fleetside.
I have a stock TH400 pan gasket with a cork gasket. Do you guys use some type of sealant with the gasket or do you just use the gasket and nothing else?
The last time I installed it a few months ago it leaked with this same trans pan and some type of composite rubber/cork gasket and a sealant that I used which seemed to take a long time to cure.
I appreciate any input.
HeavyHauler is offline   Reply With Quote
Old 03-20-2026, 07:29 PM   #2
leddzepp
Moderator
leddzepp's Avatar
Re: What sealant do you use on the TH400 with pan gasket?
I use an FIPG on all gaskets. It’s more expensive than other sealants, but it works like it’s supposed to and is used in OEM applications by Honda, Toyota, etc.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 03-20-2026, 09:35 PM   #3
HO455
HO455's Avatar
I've used CAT blue anaerobic sealant along with a gasket with good results in the past. I generally use anaerobic sealants on gaskets. Although last summer I used the Felpro sealant below on my T350 with a gasket. No leaks so far.
https://www.summitracing.com/parts/p...SABEgI1IPD_BwE
RIP Bob Parks.
Old 03-20-2026, 11:18 PM   #4
HO455
HO455's Avatar
Double post.
RIP Bob Parks.
Old 03-21-2026, 08:45 AM   #5
HeavyHauler
I am going to use Permatex Ultra Black with that cork gasket. I hope it seals Wish me luck!
Old 03-21-2026, 09:34 AM   #6
Joyridin
I use interior spray trim adhesive on the pan. Wait about 5 minutes, then put on the gasket. Flip it over on a flat surface and put some pressure on the pa for a few minutes. Install form there.
I have never had a leak.
Joyridin is offline   Reply With Quote
Old 03-21-2026, 09:42 AM   #7
72c20customcamper
72c20customcamper's Avatar
Moroso silicon gasket no sealant last year so far no leaks
Mark
1969 AMX ,
1968 c20 stepside ,85 K20
1977 Suburban sold
68 anniversary.
Old 03-21-2026, 12:30 PM   #8
kwmech
Only thing I use is gaska-cinch on the pan itself to hold the gasket in place. Other than that.....nothing. Use a quality cork gasket, make sure the pan is flat and the area around the bolts is not coned out and torque the bolts to 100 INCH pounds
Old 03-21-2026, 02:17 PM   #9
HeavyHauler
Well I got it installed and the Permatex Ultra black sealant says to tighten up the bolts snugly. Wait 1 hour then tighten to spec. Then wait 24hrs to cure.
I am just going to snug down the bolts lightly with 1/4 ratchet using light pressure after 1 hr and then wait until tomorrow to fill the trans with fluid.
I dont trust using my torque wrench for the 12ft lbs as it seemed to squeeze out the gasket and sealant too much the last time I did that.
I will just snug the bolts again and then wait for it to cure as I have had better luck in the past doing that.
Old 03-21-2026, 02:34 PM   #10
Grounded63
Straight cork gasket, no sealant.
Those are pretty much the instructions for not using a gasket at all. Like sealing a differential cover or T-case. On something like a AT pan gasket that shouldn't need a sealant to seal. There really shouldn't be enough sealant on there to squeeze out. It just makes the gasket slick. That's why it won't stay in place.
Grounded63 is offline   Reply With Quote
Old 03-21-2026, 03:00 PM   #11
HeavyHauler
We will see. It will either leak like a faucet like you say or not.
Old 03-21-2026, 03:17 PM   #12
70STOVEBOLT
70STOVEBOLT's Avatar
I may have missed it, but what kind of pan are you using? If it’s the stock pan it may have been distorted by a PO due to over tightening. Valve covers and steel trans pans only require minimal torque to seal, it a lot easier f people will crank the bolts down tight and bend the metal. It doesn’t take much. If it’s a chrome pan, those are difficult to get to seal up.
70 C/10 SWB 402/TH400/3.73 "The Needy Beast"
200,000 Mile Club
Disc Brake Club
Owner installed options:
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Sliding Rear Window
Power Windows
Power Locks
Sniper EFI
2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear
70STOVEBOLT is online now   Reply With Quote
Old 03-21-2026, 03:45 PM   #13
57taskforce
All about them K’s
57taskforce's Avatar
Permatex the right stuff has never failed me, I prefer molded silicone gaskets with a steel core where possible over cork or regular rubber.
Tyler
Old 03-21-2026, 05:50 PM   #14
Grounded63
I never said it will leak like a faucet . . .
Old 03-21-2026, 07:52 PM   #15
mr48chev
mr48chev's Avatar
When I was putting my 71 back together with the turbo 400 I stopped at a long time friend's transmission shop to pick up a speedometer drive and then bought one of the cork gaskets as if it is good enough for him it is good enough for me.
My ongoing truck projects:
Old 03-21-2026, 08:34 PM   #16
HeavyHauler
Sorry! I got your post confused with another on a different site. Hopefully it seals!
Old 03-21-2026, 10:54 PM   #17
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
FWW, I skipped the cork - and common rubber (junk) favoring a Moroso gasket #93103, with ARP bolts #651-0750 for my 400Th pan. No sealant and no leaks.
Tony 1971 C10 Custom Deluxe SWB 402/400TH A/C
I developed an assembly information kit for restoring my truck from nuts and bolts. It's written in Assy. order, short & simple, packed with all OEM hardware ID; castings; part ID; 100s of part numbers; wiring simple - Resource, and trivial too.
Much info. applies to all 67-72 GM, A/C vehicles, esp. trucks W/O saying. Full search ability, including to 700+ images of illus., parts, charts, Assy., points of interest, cab, bed, & front clip cart plans- Specials and cores were serviced out and R excluded e.g. front/rear glass, body/paint, engine core, rebuilt hinges, steering box, trans, etc.
The project was in-line with long former professions developing process, policy, specs, demo, written for novices, admin., policy, engineers, development, systems & test - Public & govt 2, gross. Sell soft copy cheaply, PM if interested.
Build thread:https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline   Reply With Quote
Old 03-22-2026, 10:55 PM   #18
HeavyHauler
It sealed with no problems.
Old 03-23-2026, 03:28 PM   #19
ullose272
i used a lube locker gasket with nothing on it and its sealed up nice. i do have a deep aluminum pan however with a machined surface.
ullose272 is offline   Reply With Quote
