Old 03-27-2026, 09:40 AM   #11
K10-Kansas
K10-Kansas's Avatar
Re: 76 K10 hubs shaky top to bottom
Originally Posted by kennyw View Post
That inner axle shaft seal is on the inside of the axle, behind the ring gear and carrier. You can remove the carrier to replace them and reinstall without setting gears as long as any shims that are present are put back in the same exact location they were removed from. May as well buy/make a tube scraper if you replace those seals to get all the grime out.
Thanks for the info. To replace the seal that is likely causing this leak, would I have to pull the differential gear out? Is this the right part on LMC's website? In the other picture, is this where the seal is? Thanks for your help on this.
1971 C10 body. 76 4x4 chassis cut to short frame. Crate 350 2nd Gen small block. 4BBL Holley 4160. 4L60 transmission. ~ James
K10-Kansas is offline   Reply With Quote
