Old 03-25-2026, 10:28 PM   #1
IT Cowboy
IT Cowboy's Avatar
Could someone measure these radio center caps please
Could I get someone to measure the metal center of the deluxe radio knobs pictured below using a dial caliper or machinist rule. I think they are .59/15mm but I dont have one on hand - thank you
1972 C10 Custom Deluxe Highlander 402
Freedom isn't safe, it requires you to take responsibility for your own life, your own safety, and your own success. It carries with it the possibility of failure and the understanding that you're working without out a safety net. If you give the state the responsibility for any of these you also give up the freedom that accompanies the responsibility.
IT Cowboy is offline   Reply With Quote
Old 03-26-2026, 12:53 PM   #2
Rust_never_sleeps
Rust_never_sleeps's Avatar
Re: Could someone measure these radio center caps please
I'm measuring that metal cap at 20mm
1970 C10 Custom longbed 350/350
“Carburetors are forgiving, timing is not” — Thunderhead289
Rust_never_sleeps is offline   Reply With Quote
Old 03-26-2026, 01:07 PM   #3
IT Cowboy
IT Cowboy's Avatar
Awesome thank you. I think I have a solution to re-create these knobs
Old 03-26-2026, 09:45 PM   #4
70STOVEBOLT
70STOVEBOLT's Avatar
I’ll sign on to see it.
70 C/10 SWB 402/TH400/3.73 "The Needy Beast"
200,000 Mile Club
Disc Brake Club
Owner installed options:
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Sliding Rear Window
Power Windows
Power Locks
Sniper EFI
2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear
70STOVEBOLT is online now   Reply With Quote
Old 03-26-2026, 10:05 PM   #5
Rust_never_sleeps
Interesting. Easy to print, but not with the metal caps.
I could sink a Fresca cap in one, I suppose ;-)
Old 03-27-2026, 07:54 AM   #6
yuccales
yuccales's Avatar
Fresca cap a tad to hillbilly. I'd try floor glides. Heat up the prongs, press into the knob, done!
yuccales is offline   Reply With Quote
Old 03-27-2026, 10:05 PM   #7
Steeveedee
Ram-A-Lam-A-Ding-Dong
Steeveedee's Avatar
~Steven
Simi Valley, CA
Old 03-28-2026, 01:06 AM   #8
IT Cowboy
IT Cowboy's Avatar
Getting closer
Old 03-29-2026, 09:42 PM   #9
IT Cowboy
IT Cowboy's Avatar
If you can' find it or buy it then make it! A bit of a learning curve but I am getting closer yet.
Name:  Screenshot 2026-03-29 181214.jpg
Old 03-30-2026, 12:18 AM   #10
Rust_never_sleeps
you'll probably want to reinforce the d-hole. Might get away with just a strip of metal on the flat part
Of course, if it strips out, it's easy enough to print another one
Old 03-30-2026, 01:21 PM   #11
Rust_never_sleeps
Fresca's classy, hillbilly would be PBR ;-)
I do have blank bottle caps for brewing, but they have "ruffled skirts" so not really suitable. I like your solution better
Old 03-30-2026, 01:23 PM   #12
Rust_never_sleeps
Attachment 2445113
Looks like you're one "pull" away from getting that center cylinder to the right length
Old 03-30-2026, 01:32 PM   #13
IT Cowboy
IT Cowboy's Avatar
That is what she said. I used calipers to measure an original so it should be ok. I could have made the back solid but I had fun creating it in Fusion.
Old 03-30-2026, 01:39 PM   #14
Rust_never_sleeps
Fusion is slick once you figure out how the selection works and what assumptions it makes based on that. Until then, it made me weep bitter tears of melancholy
