Old 03-31-2026, 07:25 AM   #33
B52bobardier1
Re: Me & My '59 Apache - The Story Begins
Hello,
I did not check the operation of the internal spinning cable for the speedometer because both ends were screwed down tightly - no looseness. I have only had this truck since last September and the cable appears almost new - installed by a previous owner.
That's an interesting question about the odometer miles wheels moving or not. I will have to check that.
I have a new "bullet gear" inside this transmission that did correct the speedometer error a little but only by 2-3 MPH. That drive gear that is deeper inside the tailshaft will require the removal of drive shaft and the tail shaft cover and I guess that is what I'm up against at this point. I have no idea which plastic gear is actually installed and I need to find these before I start this job. Its a TH350 transmission with a 3.08 set of differential gears and about 26 inches for a tire height.
Great advice above and I thank you.
Rick
1959 Chevy Apache Short Bed Fleetside 350 CI Motor
1970 Pontiac Catalina Convertible LS 5.3 Liter 4L60E Transmission
1970 Chevy El Camino 5.3 Liter 4L60E Transmission
B52bobardier1 is offline   Reply With Quote
