#326 |
landarts
![]() Join Date: May 2005
Re: Super Cheyenne aka the "Devil Cowboy"
Had a busy day in the shop. Processing the bolts for the front axle cover, getting them into paint after some degreasing and wire wheeling. Spent my lunch hour getting the trim taped on and marked with a white Stabilo pencil. I used a flexible ruler to get a few key measurements to get started. I will next remove the trim and make all of the inserts for the 3M trim tape, and install them into the trim and install to the lines drawn on the truck.
Also, have been working on clean up of the NL2 tank. Three days into soaking in Kroll oil and trying to get the carriage bolts off. I am about at the point of just cutting them off, and fabbing up new ones. Also, finally got the order of K&B tank sealer kit in so I can treat the inside and make it like new again.
Super Cheyenne aka the "Devil Cowboy" 71 K20 Idaho Edition 69 K10 from the Field 68 Second Chance Fix and Sale 72 GMC 3/4 ton 4x4 K2500 The "Fixrupr" build thread 72 Cheyenne 1/2 ton " FIXRUPR " - daily driver 67 C20 all original paint 71 K20 Custom 4x4 (Idaho Edition) 72 K20 GMC Super Custom 4x4 69 K10 Custom package 4x4 (69 K10 from the field) 72 K10 Custom 71 K10 Custom 69 K20 Custom Deluxe 4x4 71 K10 Custom Deluxe 72 K20 Crew Cab Project 71 GMC Jimmy CST 70 Blazer |
#327 |
landarts
Getting close to being ready to install the trim on the drink side. I have been going through the same process as I did on the captain's side of the truck. Cutting my own 1/8 inch ABS plastic strips and inserting for the use of an adhesive promoter and 3M VHB tape.
After using a sample I saved from the other side of the truck, I used a sliding square to get the exact size in trim width needed. I mark it with a silver Sharpie, line it up with a metal ruler, then score it a few times with the plastic score tool. Carefully open the end of the trim with a pair of flat pliers so I can then slide the plastic inside the trim channel. After last piece is in I take it over to the bench vice where I have a piece of wood in the vise jaws. Then tape down the bent-up end channels and make sure that everything is tight and flat. Next step is to add all of the 3M VHB tape, use adhesive promoter on the ABS before tape goes down, also use promoter on the truck prior to install. Stay tuned, more to come
#328 |
landarts
Here is more on the process of getting the ABS installed. Note the 4th picture down shows how much larger I make these versus the stock ones. The last picture shows all the trim parts now installed as of this morning. Hope to get it installed on lunch break or after work today.
Here is a list of items used from Amazon ABS Plastic sheeting 1/8 or 3mm thick 12x16 x 2 sheets $19 https://www.amazon.com/dp/B0CDW3W7YQ...n_title_1&th=1 3m VHB tape .78 wide 16.5 feet $14.50 https://www.amazon.com/dp/B0CZ3CK48Y...n_title_2&th=1 Adhesion Promoter 24 pack $8 https://www.amazon.com/dp/B000LNJYNA...d_asin_title_2 Plastic score/cutter $8 https://www.amazon.com/dp/B000LNJYNA...n_title_2&th=1
| Bookmarks |
