Old 03-31-2026, 12:46 PM   #1
IT Cowboy
IT Cowboy's Avatar
How are the original AM radios mounted - do I need a brace
I have an original GM Delco AM radio I am going to put in my truck. Do I need the mounting bracket / brace for the back or will it be ok using just the front cups and shaft bolts and nuts.
Right now the radio I am wanting to put in just has one straight metal tab on the back. I can probably take a piece of metal strap and fab one up if needed or even pipe strap?
1972 C10 Custom Deluxe Highlander 402
Freedom isn't safe, it requires you to take responsibility for your own life, your own safety, and your own success. It carries with it the possibility of failure and the understanding that you're working without out a safety net. If you give the state the responsibility for any of these you also give up the freedom that accompanies the responsibility.
IT Cowboy is offline   Reply With Quote
Old 03-31-2026, 01:33 PM   #2
Rust_never_sleeps
Rust_never_sleeps's Avatar
Re: How are the original AM radios mounted - do I need a brace
Not a great image, but this is all there is to it. IIRC that's just an L bracket mounting the strap to the dash. I might be able to snag a shot of the thing if I can find it on the Bench of Chaos
1970 C10 Custom longbed 350/350
“Carburetors are forgiving, timing is not” — Thunderhead289
Rust_never_sleeps is offline   Reply With Quote
Old 03-31-2026, 01:38 PM   #3
JohnC67
I think mine just had a strip of hardware store metal strap when I got it.
JohnC67 is offline   Reply With Quote
Old 03-31-2026, 01:41 PM   #4
Rust_never_sleeps
If you're old enough to remember Erector sets, you'll know what I saw the first time I looked ;-)
Old 03-31-2026, 01:45 PM   #5
IT Cowboy
IT Cowboy's Avatar
That helps thank you. Right now my radio just has the single tab bracket like by the green wire in your pic. I can fab up an L bracket from scrap and then swear a lot when trying to bolt it it. I though i have seen a pre-installed top bracket mount in some trucks.
Old 03-31-2026, 01:59 PM   #6
Rust_never_sleeps
If you can tack weld a nut on the front of the L-bracked, you could secure the bracket to dash first and then bolt the radio in with one hand
Maybe pull a duct or two first
Old 03-31-2026, 02:06 PM   #7
IT Cowboy
IT Cowboy's Avatar
I have some of those slide on nut clips that should slide right on and tighten down. I also have some gorilla tape (kidding - gorilla tape is only for visible areas)
Old 03-31-2026, 06:20 PM   #8
'68OrangeSunshine
'68OrangeSunshine's Avatar
They call it ''Plumbers Tape'' but it's not like sticky tapes. It's steel strap with perforations about every half inch. Available at any hardware store. Comes in roll form.
That's what I've used when the OEM rear radio mounting bracket gets lost.
And YES, you will need it, especially if you run your truck in rough places. The original AM/FM [or AM] Delco radios were really tail- heavy. Some more modern tuners and cassette radios were lighter, more solid state, but reinforcement in the back of the unit is a good idea in any case.
'68OrangeSunshine is online now   Reply With Quote
Old 03-31-2026, 09:03 PM   #9
CG
BlahBlahBlah
Thats a good idea. Its such a weird name for something that isnt like any tape a person would normally think of.
Old 03-31-2026, 09:58 PM   #10
'68OrangeSunshine
Don't we live in a weird but fascinating world?
Old Yesterday, 11:47 AM   #11
Rust_never_sleeps
Prolly just because you unroll it off a spool, but plumbers do have their own language, as do mechanics
Old Yesterday, 12:26 PM   #12
IT Cowboy
IT Cowboy's Avatar
I just always called it pipe strap. Flex Seal is plumbers tape -
Old Yesterday, 12:52 PM   #13
Rust_never_sleeps
Just remember, plumber's crack isn't a cocaine derivative
Old Yesterday, 11:54 PM   #14
Steeveedee
Ram-A-Lam-A-Ding-Dong
Steeveedee's Avatar
Either way, ain't no snortin' of it goin' on, around here.
~Steven
Simi Valley, CA
