Old 03-14-2026, 06:50 AM   #1
cag
Active Member
5/7 drop on a leaf spring truck??
anyone done this??
cag is offline   Reply With Quote
Old 03-14-2026, 07:07 AM   #2
MS66
MS66's Avatar
Re: 5/7 drop on a leaf spring truck??
They make leaf spring trucks?
MS66 is offline   Reply With Quote
Old 03-14-2026, 07:28 AM   #3
It can be done. Axle flip and maybe a 1 or 2 inch block. But you'll need to do a C-notch to the frame. for clearance
Old 03-14-2026, 11:08 AM   #4
lolife99
67-72 parts collector,…
lolife99's Avatar
Axle flip alone on a leaf spring truck will get the back really low. Probably more than 7” drop.
Keith
Convert to disc brakes.
Old 03-14-2026, 01:10 PM   #5
WorldsCrappiestTruck
This. I’m not sure how low I’ll be once the bed and sheet metal is back on, but I was really surprised how low it went with just the flip. Definitely requires a c-notch of some kind
WorldsCrappiestTruck is offline   Reply With Quote
Old 03-23-2026, 01:54 PM   #6
ullose272
i have dearched springs and shackles and im sitting probably 6" lower in the rear. ill likely do a flip kit in the future to get another inch
ullose272 is online now   Reply With Quote
Old 03-23-2026, 10:58 PM   #7
Mike C
Mike C's Avatar
My ‘69 short step is 4.5”/7” drop. The DJM flip actually lowered the rear 7 1/4” over stock. My truck has the HD rear leaf so that might change the total amount slightly due to spring pack thickness.
I have ECE 2 1/2” spindles and their 2” small block spring in the front. I am quite pleased with it. I have not notched it but did use small urethane bumps on the rails that I believe came in the kit.
I’m running 17” zero offset wheels. 17x8 in front ( 4.5” bs) and 17x9” in the rear (5” bs).
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 03-24-2026, 09:03 AM   #8
cag
Active Member
any pics of truck and rims??
ece spindles??
Old 03-27-2026, 12:43 AM   #9
Mike C
Mike C's Avatar
I don’t have any photo hosting anymore and it seems all my previous pics are gone. I’ll see if I can directly upload here or not.
44 Willys MB
52 M38A1
64 Corvette Coupe
Old 03-31-2026, 04:10 PM   #10
SCOTI
SCOTI's Avatar
Leaf-spring pack thickness + 1/2 the axle tube O.D. will typically tell you the amount of drop to expect.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
