Old Yesterday, 05:37 PM   #1
Loose Screw
Loose Screw's Avatar
I'm Goin In Boys, More PTFE and TH350 Servicing.
My Easter Basket ...
There's an inline fuel cutoff switch in there, PTFE Transmission Cooler/Radiator line and transmission pan w/filter. I'm Stoked!
Loose Screw is offline   Reply With Quote
Old Yesterday, 06:56 PM   #2
72c20customcamper
72c20customcamper's Avatar
Re: I'm Goin In Boys, More PTFE and TH350 Servicing.
I’m doing the same but for my gas tank
Mark
1969 AMX ,
1968 c20 stepside ,85 K20
1977 Suburban sold
68 anniversary.
Old Today, 12:48 PM   #3
Loose Screw
I'm putting this fuel switch off the gas tank sending unit's 5/16s steel fuel line. Got one of the choke down ferrule/pumpkin adapters on the steel line and switch installed and start to put the other (packaged) "5/16s" adapter on the fuel line and it won't go on!!! Calipers read the OD is point 24...d*mn thing is Packaged Wrong!
Thank Goodness I didn't choke down the first installed adapter because I had to remove it and put some rubber fuel line in there to move the truck out of the garage so I could close the garage door at 11:30 last night till I can get ahold of Summit on Monday...
Check Your Parts Boys!
