Rear Brake Line, Need One, is Burb Same as Truck
I have a 2wd C10 72 Burb with a 12 bolt rear. When I changed wheel cylinders on the rear brakes I messed up the passenger side rear brake line. It is a steel brake line that goes from just above the differential to the passenger side rear wheel cylinder (drum brakes). Need a new one. Does anyone know where I can get a new pre-made brake line. Ricks, Impala Bobs, or etc...??? Also, is it the same as the brake line for a truck of the same year with the 12 bolt rear?
Thanks, Jeff
72 C10 Burb 350 700R4 70 C20 LWB 350 Crate TH400 68 Chevelle Last edited by rn2fine; 09-04-2004 at 06:10 PM. |
You have options. If you don't care about the spring stone guards like the orig. line had, you can bend a pre-cut and flared line of the same length from a auto parts store, and bend it yourself (done that when in a similar situation... or you can order one from one of the vendors listed on the opening page of this board. I bought my lines from here www.rightstuffdetailing.com
'72 GMC SWB C1500 Custom, frame-off in progress. 383 SBC, 9:1CR, Comp Cams XE262H, Scat internal balanced crank, Eagle SIR 6" rods, Keith Black dish pistons, Dart Iron Eagle 72/180 heads, Weiand Stealth intake, Stewart stage I water pump, Holley 4bbl vac sec, TH350 with B&M Shift Improver Kit. 12 bolt positraction. ![]() ![]() ![]() |
I know several of the guys at "The Right Stuff" and I can tell you that their parts are top quality and the service excellent.
I checked out the link that you guys sent me and the company looks like they do great work. Their web-site catalog however does not show truck applications or applications for a 1972. I am going to call them on Tuesday. I did find a company that sells a rear passenger side axle brake line for a 72 C10 Pickup. If anyone out there has a 72 C10 pickup with a 12 bolt rear could you take a digital picture of the passenger rear axle brake line that goes from just above the differential to the wheel cylinder. I want to see if it is the same as my Suburban.
Thanks, Jeff
72 C10 Burb 350 700R4 70 C20 LWB 350 Crate TH400 68 Chevelle Last edited by rn2fine; 09-04-2004 at 06:13 PM. |
I have a 70 truck & 71 Burb and they are the same.
![]() ![]() 99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs 95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI |
Thanks Neon. I appreciate you checking it out for me.
Jeff
72 C10 Burb 350 700R4 70 C20 LWB 350 Crate TH400 68 Chevelle |
