Old 09-05-2004, 09:36 PM   #1
crazy longhorn
Fabricate till you "puke"
Elect fans, 2nd go around
The old 69 is running a pair of 14" flex a lites on a home built shroud. I installed a painless kit(185 on, 170 off). the 1st thing was not an overheat problem, but the fans ran all the time @ idle(with a 180 stat). I installed a 160 stat, & those fans kick off/on ......watched her idle for 1 1/2 hrs! not too bad on a 4 row copper/brass rad, huh? I just hope she dont run too cool......i like to see them 180-185, & this one runs tween 170- 182! bet she will be on the bottom side of that temp, cruisin down the hyway crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 09-05-2004, 09:49 PM   #2
rage'nrat638
rage'nrat638's Avatar
Sound's Like A Great Way To Go......
Aaaa......where You At In Ill??????
I Am In Aurora..... :d
rage'nrat638 is offline   Reply With Quote
Old 09-05-2004, 10:05 PM   #3
crazy longhorn
Im in Rock Island.....try to keep a low profile, the old chev is not quite hot enough for the 1320, but too hot for the street crazyL
