Old 09-04-2004, 01:03 AM   #1
jackleg
quieter cab
I just bought a 71 K10 w/headers and 40 series flowmasters. I planned on swapping out the 40 series for either the 50 or 70 delta flow. I also just finished replacing the weatherstripping on the door and vent windows but the cab there's still a lot of wind noise on the highway. I was wondering if dynamat and similar products really work and what else can I do to cut down on noise?
thank you
jackleg is offline   Reply With Quote
Old 09-04-2004, 02:51 AM   #2
Russell
Professional Grade
Russell's Avatar
Replace all of the seals and put down some of that dynamat stuff -- I hear it works wonders for quieting stuff down...
How big of an inlet / outlet do the Flowmaster 40s have, and how much would you want for the two of them shipped up to me in Canada?
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap)
Russell is offline   Reply With Quote
Old 09-04-2004, 03:17 AM   #3
jackleg
They're center in/out w/ 2 1/2 in. pipe. I'm in between jobs right now so I'm not gonna replace them for a few weeks. If you want, I'll let you know when I get the new ones and ship'em up to you to from Kalispell, MT for $20 a piece plus shipping.
Old 09-04-2004, 05:00 AM   #4
krue
Designated A-hole!
krue's Avatar
Welcome to the board from South Mississippi! My cab is quieter than say a tornado, but that's about it. I think all the air rushing in thru the holes in the floor may have something to with it tho!
"If it ain't broke, fix it 'til it is!"
Being stupid ain't illegal.
We're Still Debt Free Except for the House!!!
www.daveramsey.com
70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e
93 S-10 "Poppaw's Truck"
krue is offline   Reply With Quote
Old 09-04-2004, 06:08 PM   #5
Just knock the muffler off Krue and you'll never notice that wind noise again!!!
Old 09-04-2004, 07:20 PM   #6
neonlarry
neonlarry's Avatar
Dynamat (thats what I used) or something simular will certainly reduce the noise inside your cab. But it will not reduce your wind noise, in fact it will probably be more noticeable. I would check to see if all your new weatherstripping is sealing like it should. But no matter how well it seals you are still going to get a certain amount of wind noise.
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights
99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs
95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI
neonlarry is offline   Reply With Quote
Old 09-04-2004, 08:12 PM   #7
Curbstone Mech
Active Member
You could try checking for air gaps around your door seals by riding with a friend and having him (or her) feel around the door for leaks. Also, check to see if your wing windows fit tight against the seal. If the doors have any gap at the top half, you can bend the door frame in (with the window down)
You could also check for gaps by mixing some chalk dust into a paste, put it around the seal and the close the door- if there is a place where there is no chalk dust transferred, that could be an air gap.
If your wing window doesn't seal tight, you could use a shim, like a dime or penny between the upright and the handle to keep it tighter.
68 short fleet
383 stroker, 700r4 373:1 posi
72 GMC 3/4 ton- weekly driver
700r4 351;1 posi
Curbstone Mech is offline   Reply With Quote
Old 09-04-2004, 08:59 PM   #8
Russell
Professional Grade
Russell's Avatar
How much do you figure shipping would be? They sound exactly like what I need I want a set of Aerochambers, but the flows will work fine for now
Old 09-04-2004, 10:13 PM   #9
thisolechevy
When I got custom interior in my '69 k-10 I put down FATMAT it works great I put 3 layers on the floor, 2 on the back wall behind the tank, 2 under the dash, d behind door panels...I think thats all :-) and it works great!!!!!!! FOR ROAD NOISE
Now for wind noise also check the drip rail if there are holes in it, it will create a lot of wind noise.
Man I need another 67-72!!!
thisolechevy is offline   Reply With Quote
Old 09-05-2004, 08:04 PM   #10
Russell
Professional Grade
Russell's Avatar
TTT
Old 09-05-2004, 09:25 PM   #11
67ChevyC10Stepside
67ChevyC10Stepside's Avatar
im interested in those mufflers too....how old are they?
67 c-10, 400 SB, TH350, 4.10 gears, Blazer tank,camaro tach, sidemarker fuel fill (soon)
WTB: stepside parts, 67 front end parts, 67 small window cab. posi for 3.73 or 4.10 for 12 bolt and 10 bolt.
67ChevyC10Stepside is offline   Reply With Quote
Old 09-06-2004, 08:50 AM   #12
68C15
blood type; Retumbo
68C15's Avatar
I dont think you will ever get rid of the wind noise due to the design of body. too many parts sticking out causing the air to mix up & cause noise. (eyebrow above windshield, "A" pillars out from door frame, "B" pillars out from door also, etc...) that is why newer cars & truck have everything flush mounted.
side note: what kind of mirror do you have?
Man rule #77...if you own a 67 stepside with a caddy 472 you will never be in danger of loosing you man card
68C15 is offline   Reply With Quote
Old 09-06-2004, 01:10 PM   #13
kxmotox247
kxmotox247's Avatar
Did you have any problems with it being too thick on the floor and interfering with the set mounts, gas pedal, etc??
I have some fatmat on the way. I've been worrying that the carpet won't fit right if I put too much down.
kxmotox247 is offline   Reply With Quote
