Old 09-06-2004, 06:22 PM   #1
bean
need help
I have a 69 with a strt 6. Problem is when it warms up it seems to run rough. If I get it on the highway and drive about 20 minutes it will die when I pull off to exit. Otherwise the truck runs great. The engine was rebuilt about a year and half ago. What's up?
bean is offline   Reply With Quote
Old 09-06-2004, 06:36 PM   #2
Sweet72
Sweet72's Avatar
Next time it does it see if you're getting ignition, if not your coil is probaby the culprit. If spark is ok, maybe it's vapor-locking.
'72 GMC SWB C1500 Custom, frame-off in progress. 383 SBC, 9:1CR, Comp Cams XE262H, Scat internal balanced crank, Eagle SIR 6" rods, Keith Black dish pistons, Dart Iron Eagle 72/180 heads, Weiand Stealth intake, Stewart stage I water pump, Holley 4bbl vac sec, TH350 with B&M Shift Improver Kit. 12 bolt positraction.
Sweet72 is offline   Reply With Quote
Old 09-06-2004, 06:41 PM   #3
rage'nrat638
rage'nrat638's Avatar
Thumbs up maybe....
remove air cleaner.....be careful....while running place hand over the top of carb....to limit the air intake....not covering completly....
if it idle's up...you got a vacuum leak.......
could be that while cold choke is on.....running richer....after warm...no more choke....thus leaner mixture.....engine no likey....
just a thought.....
your pal....mark
rage'nrat638 is offline   Reply With Quote
Old 09-06-2004, 06:42 PM   #4
bean
If its vapor locking what would I do. The coil is a petronix and isn't all that old but I'll keep that in mind. Anything else you can think of?
Old 09-06-2004, 06:45 PM   #5
bean
This truck still has the original manual choke.
Old 09-06-2004, 06:52 PM   #6
rage'nrat638
Thumbs up
may still have a vacuum leak....
try the hand...over the carb....trick...can also spray carb. cleaner around the lower carb. base and manifold while running to check throttle plate rod seals
and base gasket..and intake to head gasket....
Old 09-06-2004, 09:47 PM   #7
obsesive23
Who me?
obsesive23's Avatar
My vote, the coil is the culprit. In my experience when they are about to give up the ghost they tend to malfunction when they warm up.
Living the dream
72 2WD Blazer, under going porter built surgery
67 GT Mustang fastback
67 Mustang coupe C/S clone
64 Falcon sprint hardtop
obsesive23 is offline   Reply With Quote
Old 09-07-2004, 06:58 AM   #8
bobs409
1969 Custom 30 wrecker
bobs409's Avatar
I've had that happen too, they get "funny" when they get warm. Mine used to be hard starting when hot, acted like it was flooded but it wasn't. Turned out to be either the coil or the module going bad. (not sure which it was since I replaced both at that same time)
Bob
63 Impala 283/PG/3.36 (under restoration)
66 Impala 327/PG/3.36
66 Chevelle SS 409/M22/3.55
69 Chevelle 307/PG/3.08 (future restoration)
69 C10 short stepside 454/TH350/3.73
69 Custom 30 tow truck 350/4 spd/4.10 (resto done, CRUISIN TIME!)
71 Cheyenne 20 fleetside 350/4 spd/4.10
71 Chevelle 6/PG/3.08
72 Chevelle 454/M21/4.10
bobs409 is offline   Reply With Quote
