Tips on gas tank removal?
I'm going to be pulling my in-cab gas tank this week and was looking for tips or advice on doing it. I'm going to try to siphon most of the gas out before I do it. Any tips or advice on doing this? I want to insulate the back of the cab with some dynamat for noise reduction.
Thanks, Josh
Baby Blue's Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=652776 Project 68's Build Thread: http://67-72chevytrucks.com/vboard/s...17#post8442117 www.stonecolumnclassics.com Email: Josh@stonecolumnclassics.com |
It's real easy. Just remove the seat, and then all the bolts around the tank, (i think there is about 6 0r 8) then the sending unit wire, and then disconnect the fuel line. You may need to push the fuel line forwars slightly before the tank will come out. Slide the tank towards the pass side first with the fill cap off. Then when it comes through the grommet on the side put the cap back on.
Good luck! Oh. and keep an eye out for the build sheet behind the gas tank. Make sure you save it if you find it back there. ![]() Darren
Washington State 1967 Chevy C10 LWB Rodstoration In Progress. 1972 K20 Cheyenne Super |
I forgot that there might be a build sheet. There is no sticker in the glove box and I've been wondering what was on the truck from the factory.
Sounds pretty straight forward. The only other thing I had a question about was that my seat doesn't fold forward. I didn't realize that some seats were "fixed". I hope it's worth insulating behind the tank. The road noise coupled with the exhaust is out of control in this truck. By the way....thanks!
If you soap up the grommet around the fill tube it will come through a lot easier.
Jim |
user # 2756
![]() Join Date: Jun 2001
Make sure you run it dry also. A couple gallons of gas moving around does not help.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs 1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX 1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears 1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now..... 1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone. 1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed. 1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm ![]() |
Cantankerous Geezer
I siphon what I can, the drain the rest into a 5 gal bucket. And be sure to smoke while you're underneath draining what's left in the tank.
Fred There is no such thing as too much cam...just not enough engine. ![]() |
Thanks for the good tips. I might get started tonight.
Anyone have any good techniques for siphoning?
![]() ![]() Join Date: Jul 2002
Yeah, use of a siphon pump is preferred, or have one of your teenagers do it.
![]() Join Date: Nov 2003
I pulled my tank last night, there were 7 bolts holding it in. I greased the filler tube a bit and it didn't give me any trouble.
The vent hose running up the side of the cab can be tough to get out. Here is the method I used last night: Pull on it, realize it's stuck and won't come out. Try to bolt it back in, figure out that you moved it down and can't get the bolt in. Push it up real hard trying to get the bolt to find the hole, hit your thumb on the sharp cab edge and cut the he!! out of it, when you are done cussing realize that as a reaction to getting cut you pulled the vent tube out, and it's now laying on the cab floor.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs. |
Now that sounds like fun, at least you don't have to put it back.
![]() ![]() 99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs 95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI |
