09-04-2004, 12:36 PM | #1 |
Garage Queen Material
cheapest place to buy posi/gears??
i'm looking for the cheapest place to order an eaton posi unit for my 10-bolt rear end and some 3.73 gears to go with it. i've currently got 2.73's
09-04-2004, 05:04 PM | #2 |
West Coast Differentials
Randy's Ring & Pinion National Drivetrain Drivetrain Superstore Check out those three places. I'm going to get my posi/install kit from West Coast, only because they're about an hour away. |
09-04-2004, 05:45 PM | #3 | |
Happy to be here
It didn't really "need" the axle bearings at the time but while it was apart I wanted "everything" to be new.... |
09-05-2004, 12:54 AM | #4 | |
randy's rind and pinion is the place i remember. they had the cheapest posi unit i've found |
09-05-2004, 03:49 PM | #5 |
jegs has a seperate install kit for our trucks w/richmond gears ($130) any idea if this is worth the extra money or just buy the complete kit for 90
also looking to upgrade gears |
09-05-2004, 04:29 PM | #6 |
Watch out for your cornhole !
Summit and Jegs are going to be free shipping. Think about that if someone else seems cheaper, because those gears and differential are heavy as heck and UPS is going to hurt you a little on shipping prices.
09-07-2004, 01:22 PM | #7 |
www.73-87chevytrucks.com
I got mine from Randy's. I told them I needed the kit to replace everything in the rearend except the axles.
Chris Lucas 1973 Chevy C-10 1978 GMC Jimmy (2WD) - SOLD 1987 R10 twin turbo LS 1991 R3500 SRW CrewCab 1985 K5 diesel swapped project 1989 K5 2WD conversion w/ Vette susp Project Captkaos Customs 73-87chevytrucks.com |
09-07-2004, 02:00 PM | #8 |
STILL PLAYS WITH TRUX
Eric,
Have you ever considered using a PowerTrax posi unit there really easy to install and no special tools or expensive posi gear oil is required and they preform as good or better than any clutch disc posi unit iv'e ever used. I know you will have to set the rear end up anyways when you install the new gear set but any time you open the rear up for routine maintenance BAM! 40 bux for posi gear oil |
09-07-2004, 04:15 PM | #9 |
about how much does it cost to get them installed
09-07-2004, 06:45 PM | #10 |
ROCKET POWER!
I just bought a PowerTrax No-Slip locker for my 12 bolt. Haven't installed it yet though, waiting on my ring&pinion&install kit. But it sure is a NICE piece of equipment, and like said no cluthes to wear out or cones to bottom out.
BTW, most install kits i've seen do not come with wheel bearings&seals, but it should not be a problem for anyone.
What did i do last nite? I had a wonderful time, That's what they tell me What did i do last nite? 1979 C-10 shortfleet: Olds 350, Th400, 12 bolt Current project: 1969 Olds 455 W-30, needing a rebuild |
