Those that are low..I mean LOW!!!
I picked up a 70 short bed stepside. I've always wanted this style of truck, and I got this one for a decent price. But, being in the rustbelt, she's gonna need some work.
Anyhow, I bought this truck specifically to bag, and to tuck 20's. I've been browsing the forum for a while now, and have checkout out tons of the different threads. Went through all like 20 some pages of the crossmember drop thread, etc. I noticed all the pics of everyones truck, is a fleetside. I know Im gonna have to step notch the rear to get really low, but Im worried about the tires hitting the top of the fenders. Fleetside guys can notch the fenders without looking bad cause you could cover the bed, or even raise the fenders inside the bed without it looking bad. I was taking some rough measurements, I think with a 27-28" tire that'll just give me enough when I eventually get the rocker on the ground. For those guys that are railing it, what size tire are you running in the rear, and are you hitting/cut the top of the fender? |
Watch out for your cornhole !
![]() Join Date: Jun 2003
I have a 28 inch tire on the back of my stepside. There's miles of room up in the fenderwell for tire clearance. The fleetside bed uses the wheelwells which are much tighter. There is no wheelwell in a stepside truck. You can tuck the tire all the way up till it hits the inside top of the fender.
Mine is dropped 6 inches in the rear, and there's plenty of room, that the frame could touch the ground before the tire rubbed the fender.
Thanks again man. Got any pics of your truck?
Back from the Dead
Heres a few pics of a bagged stepside thats running pretty low...looks like he's running 17" cragars in the first pic and 18's in the second one...seems to me that you should have enough room...but with a bodydrop I'm not sure. Hope these help!
Kenny
The only Carb that matters to me is the one under my hood! Salem, Oregon |
see the link in my sig for pics of my burb
#6 | ||
Seņor Member
Back from the Dead
What about tubbing the bed with inner fenders as well so you could mount a wheels with more positive offset....or narrow the rearend? Just a thought...
Kenny
I did notice that the fenders taper down as the go out. I was trying to measure from right at the edge where it was the lowest. I guess I'll pretty much just have to wait and see.
#9 | |
Seņor Member
www.loweredd.com
I had a 305/50/20 on all 4 corners, with the rocker on the ground, and no rubbing in the front. The rear did a VERY little. That was from dragging the backend though, which was with the front ALL the way up and the back down, which would put the back lower then if it was sitting with all corners down. (if you know what I mean) On the front, the top of the tires would tip in before they hit the fender. I had to go with a shorter tire in the front becuase it would have hit on the lip where the hood closes at the top of the fender.
#11 | |
Seņor Member
#12 | |
www.loweredd.com
