71 3/4 ton camper special front coil springs
Front coil springs for a 1971 3/4 ton, what fits?
I ordered some heavy duty springs from NAPA, but they did not fit. There is a "D" on the top arm that the spring need to fit into and then line up with the bottom arms seat. I did some searching and found AC Delco springs at rockauto.com, and MOOG at carparts.com The question is the MOOG 6104 spring, states, "Exc. Dbl. Duty". The A/C delco springs state ACDELCO Part #45H0012 Sprint FRT -;D-D HeavyDuty Spring {#88913325} The second number is the GM part number. Does anybody know what the double duty is? Most catalogs state exp DD, I went to several parts stores. ![]() |
