09-06-2004, 01:14 AM | #1 |
one set closer
Trailer Hitch
how hard is it to modifed a trailer hitch from a jeep cherokee. someone had did this but i can find it (NO SEARCH).
09-07-2004, 11:25 PM | #2 |
one set closer
ttt
09-07-2004, 11:36 PM | #3 |
hitch
well with a welder you can do anything....
here's my rewelded bumper and hitch....on my 69 tow beast.... Last edited by rage'nrat638; 07-12-2007 at 07:05 AM. |
09-08-2004, 12:50 AM | #4 |
Got Light Emitting Diode?
that might have been me you are talking about. i just flip'd it for a hida-hitch. just finally got around to trying to install it. got all of the holes drilled now just need to cut through the roll pan. i just turned it upside down and made some new brackets and it sits right behind the license plate
1968 1/2 ton 2wd lwb 6 lug disc and bags up front. Next c notch and rear bags '02 Chevy Silverado LT ext cab short bed 2WD 5/7 drop on 22's(the family car) 1993 Cherokee work ride/weekend wheeler |
09-08-2004, 08:36 AM | #5 |
one set closer
which bracket did you have to add. the part that is on the end and do you kwow what model jeep you got yours from. thanks.
09-08-2004, 08:44 PM | #6 |
the bracket that has the holes in it that bolts to the frame. i cut what i needed off of the original brackets and had my friend take it to his work and weld it, because of the thickness and weight potential i wanted them to be deep welds. it was off of a mid 80's cherokee, not sure exactly what year. the frame rails were exactly the same width as my chev. if this helps it had a 'hurricane' 4 banger w/ a 5 speed and was a 2 door. i am finishing it up tonight, will post pics when done
09-08-2004, 11:33 PM | #7 |
well for those of you that like pictures here it goes.
if the pictures are in order......... #1 i found the four corners with a 1 inch hole saw so they would have a radius, then cut it out with a cut off wheel #2 all of the way cut out and sanded with a flapper wheel that fits into the die-grinder #3 i put some of the door edge protector around the edge to make it look good #4 front picture with hitch installed #5 side view with hitch installed
09-08-2004, 11:36 PM | #8 |
#6 with stinger poking out of back (probably get a longer one so its not so close to the tail gate but it works)
#7 plate back on and #8 hitch reveal underneath
