Old 09-08-2004, 12:26 PM   #1
patgizz
patgizz's Avatar
lowering springs vs. my bump stops
i was under my truck with the weight on it finally(dropped motor in monday night). the bump stop is about 3" from where it contacts the frame, but is on a rather large platform/spacer up off of the lower control arm.
when i install my ground force drop springs, this bump stop definitely needs modified or removed.
what have you done to yours? is there a bolt on(or close to it) one available from a different gm model?
1968 C20 292/sm465
1990 C3500 dually 454/th400
1991 sonoma 4.3/700r4
1994 K1500 burb 350/4L60e
1954 belair, 1991 corvette, 1972 chevelle, 1995 LS swapped impala SS
patgizz is offline   Reply With Quote
Old 09-08-2004, 08:00 PM   #2
MidnightBlues
I just sawed of an inch or two.works very well.
*Andre*
1984 C10 SWB, 350/700R4
MidnightBlues is offline   Reply With Quote
Old 09-09-2004, 08:07 AM   #3
88Jimmy4x4
88Jimmy4x4's Avatar
Thats what I did....just trimmed an inch or so off the rubber....works fine with my 3" drop springs.
2008 Silverado Z71 RCSB
1991 GMC Jimmy 4x4
1976 GMC Sierra C15 SWB
88Jimmy4x4 is offline   Reply With Quote
