09-01-2004, 07:09 PM | #1 |
Which master cylinder-disc conversion????
I am in the process of converting my 68' to disc brakes. I also wish to replace the original type power brake booster with one from a 3/4 ton. I am confused on which booster to use on my truck.
Should I order a booster for a 68' or one for a 72'? The reason I ask is that there are different ones listed AND I want to be sure it is compatible with my new disc brake master cylinder. I also have heard that the brackets are different between the 2 years--true or false? If so can mine be modded if a 72' booster is needed? Thanks!
Dennis 68 GMC SWB Custom 1/2 ton, 2WD, 350 V8, PS, PB, 3-Speed, 3:08 12 bolt rear, tilt, tach, vac, cruise and more. . . . |
09-03-2004, 07:39 AM | #2 |
ttt
09-09-2004, 09:12 AM | #3 |
Anybody???
09-09-2004, 12:55 PM | #4 |
Keepin an eye out
You will want a 71-72 1/2 ton booster/master cylinder and prop valve. You can get them new from board vendors or try a wanted post in the parts section.
1970 Chevy C10 SWB 5.3 1996 Toyota Tacoma SR5 4x4 2007 Vespa GTS 250 Scooter ZIP 91351 |
